I got a non "k" Intel i5 4690 @ 3.85GHz (with turbo boost) that is overheating while gaming (100°C is not rare in games like Battlefield 3/4, Star Wars Battlefront..) My story with this issue started when I was looking for the cause of sudden fps drops in Battlefield 4, the drops were registered in peaks (for instance it used to run at ~100-135fps and droped to ~70-80fps and back to 100-135fps) these drops never lasted for more than 2 seconds. One importat thing to notice is that that's the fps range when the system was built, nowadays it runs at about 70-100fps. So i started looking for the cause of these 2 kinds of drops (the "peak drops" and this "overall fps drop"). Then I started monitoring clock and temps of the GPU and CPU. At this moment I realized that the processor was running at this temp. It runs with the stock Intel cooler ever since i built it (December of 2014) and my greatest fear is that it is losing its processing capabilities, due to this overheat in the long term, in a point that is no longer able to "run in the same speed as the GPU" - that would explain the fps drops experienced in games. The system has never shut down because of the heat, it seems to keep 100°C as a maximum value for the temperature so it never gets above it. What temperature should it be safely running during gaming?
My system:
GPU: EVGA GTX 970 SC FTW @ 1164MHz Base clock ~ 70°C - 376.33
RAM: Corsair Vengeance 8Gb (2 x 4Gb) @ 1600MHz
CPU: Intel Core i5 4690 @ 3.85Hz ~ 100°C when gaming (~ 50-57°C idle)
PSU: Corsair CX 600W
OS: Windows 10 Pro 64Bit
MBO: Gigabyte Z97X - UD3H BK Black Edition
I don't know if the overheat is either caused by some factory malfunction or if it's a long term issue that should have been fixed right after its assembly. Can this overheat really cause any damage to the CPU?
I still haven't found what is causing the fps drops in the games. Is it possible that the overheat is causing the them? Does anyone have an idea of what may be causing it?
PS.: I also don't know if replacing the intel stock cooler by another one will be enough to reduce dramatically the temperature to about 60-70 when in full load.
I don't know what to do...
Thanks in advance!
Have a nice day!
My system:
Thanks in advance!
Have a nice day!
