i5 4690k 980ti low fps
hiyogozi
24
so i just picked up a evga 980ti hybrid and im getting some shit frames in all games even when my usage is 80 to 100% my specs are i5 4690k stock clock a evga 980ti hybrid stock 16gb of corsair vengeance ram 2400mhz 1tb hardrive and a samsung 850 500 gb SSD and a 600w power supply and a z97x gaming 7 mother board and i just reinstalled windows 7 after seeing some bad frames in games like bf4 with my 980ti on max settings i was geting 60-80 fps which is horrible with a 980ti so when i wiped windows and reinstalled i was getting the 100-180 fps in bf4 i was looking for and i was happy and now my frame rate went back to the 60-80 fps it was before the reinstall and i dont know what to doi thought it was my pagefile usage that was killing my fps but now i just dont know i could really use some help please like i said before my frames went from bad to amazing for a little bit back to bad please solutions only
i5 and gtx 980 Ti is a fine as combo.
600w PSU will be tight dependent on the OEM of PSU,
it feels to me like its software related, maybe an anti virus is holding you back
Well, you're well off then
Just use vsync in every game, and you'll be getting CONSTANT 60 FPS in every game.
1) 980 Ti is a waste on 1080p, it's great for 1440p
2) you should have bought a gtx970, it's cheaper and perfect for 1080p
3) you have to consider that fps isn't everything! Getting 120fps is pretty useless, ESPECIALLY without v-sync. 60fps is the PERFECT gaming experience and trust me, you won't even notice the difference between 60 and 120fps
