I5-4690k Overclocking , Max Safe , Temps , Voltages.
KGliG0R0V
21
Hello , i have mine i5-4690k now running on 4.6 Ghz 1.295 V .. i thought about .. lets ask if i can push it further !
I Have a Custom Waterloop on it so cooling isnt a problem ..
i wanted to ask the best safe temps/voltages for this cpu ..
Here Are My Specs :
i5-4690k @4.6 Ghz 1.295V | 16 GB HyperX @OC 2600mhz | Msi Gaming R9 280 3Gb @OverClocked | CoolerMaster 600B Watt | Corsair Carbide R200 Modded By : Kiro Gligorov | HDD : 1x 2.5 WD Blue 500 Gb / 1x 3.5 WD Blue 500 Gb | WaterCooled By : Alphacool | Msi Gaming R9 280 / BackPlate Made By : Kiro Gligorov | Bottom Case Plate Made By : Kiro Gligorov l HDD Front Plate Made By : Kiro Gligorov | Case Window Made By : Kiro Gligorov | Ram FrontPlate Made By : Kiro Gligorov l
See Here The Pictures : http://on.fb.me/1ybnqqz
Have you stress tested it at 4.6 yet?
You need to run prime95 using 100% of the processor to ensury it is stable after every change, that will also show you your temps.
i did its stable .. 60 max on stress tests now .. ambient is 19-20c . soo..
I'm getting the same cpu. Was wondering what oc did you manage to get in the end?
Thanks
