G geforcegtxinfinity Distinguished Jun 11, 2016 24 0 18,510 Feb 22, 2017 #1 What clock speed should I overclock my i5-7600k to in order to avoid bottlenecking my gtx 1070?
The_Staplergun Estimable Jan 30, 2017 1,395 0 2,960 Feb 22, 2017 #2 It shouldn't bottleneck at even stock speeds. Upvote 0 Downvote
Eximo Titan Ambassador May 27, 2010 28,372 5,766 144,340 Feb 22, 2017 #3 Indeed, but 4.8Ghz seems to be pretty easy for Kabylake, so I would give that a go. Upvote 0 Downvote
Eximo Titan Ambassador May 27, 2010 28,372 5,766 144,340 Feb 22, 2017 #5 Indubitably. *affixes monocle* Upvote 0 Downvote
dextermat Splendid Sep 21, 2007 4,956 0 24,960 Feb 22, 2017 #6 Hi, what cooler are you using ? Upvote 0 Downvote
The_Staplergun Estimable Jan 30, 2017 1,395 0 2,960 Feb 22, 2017 #7 Look, this is overkill for the thread. He doesn't need to OC. It won't bottleneck. If he is curious about doing overclocking, that's a whole different matter. Upvote 0 Downvote
G geforcegtxinfinity Distinguished Jun 11, 2016 24 0 18,510 Feb 22, 2017 #8 I'm using the Be Quiet Pure Rock CPU cooler. Upvote 0 Downvote
G geforcegtxinfinity Distinguished Jun 11, 2016 24 0 18,510 Feb 23, 2017 #9 Can I overclock the i5 7600k on a 600-watt PSU? Upvote 0 Downvote
G geforcegtxinfinity Distinguished Jun 11, 2016 24 0 18,510 Feb 23, 2017 #11 Sorry I forgot to specify the clock speed that I wanted. I was hoping I could overclock the i5 7600k to 4.5Ghz on my 600W PSU. Upvote 0 Downvote
The_Staplergun Estimable Jan 30, 2017 1,395 0 2,960 Feb 24, 2017 #12 It won't make enough difference. 600w is enough to run even my build overclocked. Upvote 0 Downvote
