i5-8600k Cooling Help
Ccharge
Commendable
Mar 26, 2016
8
So, I'm attempt to build a PC for the first time, I have owned other PC's but have never made my own parts list before. I'm fairly happy with what I've chosen but I need some help with cooling, I'm totally lost.
I've chosen an i5-8600k, and I do want to be able to overclock it, though I'm not sure to what degree.
The case I've chosen is a Corsair Carbide series 100R. It only has 150mm of space for a cooler according to Corsair's website. This limits my size on air coolers.
So what I'm looking for this is: A cooler capable of supporting overclocking to a moderate degree or better that hopefully fits in the 100R and isn't insanely expensive, though I would rather spend the extra money than face large performance losses due to heating. I know... its a lot of requests.
If the 100R is too restrictive can anybody suggest a case in the same price range with a similar setup with similar noise levels?
I am going to exceed your price point a bit.
I really think you will be happier with something like this, You will want four of the fans, so add $80.00.
CPU Cooler: Noctua - NH-D15S 82.5 CFM CPU Cooler ($78.99 @ Newegg)
Case: Fractal Design - Define S ATX Mid Tower Case ($59.99 @ Newegg)
Case Fan: Noctua - NF-A14 PWM 82.5 CFM 140mm Fan ($20.49 @ Newegg)
Total: $159.47
Generated by PCPartPicker 2017-11-06 06:54 EST-0500
Total: $159.47
