i5 8600k Msi Z370 A-Pro OC help
Jun 28, 2018
Current Build
i5 8600k
MSI Z370 A-Pro
Cooler Master MasterLiquid ML240L RGB Liquid Cooler
Noctua NT-H1 Thermal Paste
8 gb DDR4-2133MHz
MSI GeForce GTX1050Ti 4GT OC 4GB GDDR5
Kingston SSDNow A400 240GB 2.5" SSD
Seagate 1TB HDD
Cooler Master MWE 650W 80Plus Bronze
Hey Guys,
I have zero and I mean zero OC experience. I've searched up some tutorials but every motherboard has different settings and I have no idea what to do. If anyone can help me OC my i5 8600k to 5.1 or 5GHz it would be much appreciated especially with the terms specific to this motherboard.
Cheers
Hi kenebay2399,
First, overclocking, not done properly, can damage even kill a component. Be aware of that.
Second, we can't give you specific value to achieve what you want, every system is different which means different voltage-frequency-temperature.
The rule of the overclocking is the following :
First let everything on auto,
then stress test and note your CPU voltage and CPU frequency and put them manually in bios.
Then you have two path to follow :
1°/ Better performance :
Bump your multiplier until it's not stable then bump voltage (increments of 0.025-0.05V)
Once you've reach the frequency you want, lower the voltage as much as you can as long as it remains stable.
2°/ Better thermals
Keep stock frequency and reduce voltage as much as you can until it's not stable.
FYI, i have the 8600k on the MSI SLI Plus so we have the same bios (easier to help)
Rodolphe.
