i7 4770K randomly overheating
Happy Hugo
Hi
So upgraded my old AMD CPU with a new i7 4770K. Every thing went nicely I stress tested the system at stock with Prime95 10 hours, no errors and the CPU around 47°C.
So I decided to overclock it a bit, I clocked the cpu @ 4.2 Ghz (1.2V) and did a stress test.
Got around 55°C and the fans on my h100i was around 60% (need it to be quiet).
I ran the test for 2 hours or so, after 15 minutes checked a last time before bed.
The system had overheated, I rebooted and and checked my temps during a stress test.
It quickly heated up to 90°C, didn't find out what was wrong so I reset everything back to stock.
And now the system randomly overheats at stock settings. Help please!
Don't over clock your Processor...without the proper guide and Knowledge abt OVERCLOCKING
rest ur BIOS and everything wil be Normal.....or remove ur CMOS battery and insert it agian....
$10 says your BIOS is still set to 'Adaptive Voltage.' When using adaptive voltage and stress testing the motherboard tends to deliver more voltage then required thus overheating your processor
