i7-4770K Stock Air Cooler Question
markordinance
47
Good afternoon everybody,
Would the stock air cooler be enough for this build?
http://pcpartpicker.com/user/Sieghrain/saved/41DT
CPU Intel Core
i7-4770K 3.5GHz Quad-Core
Motherboard
Asus Z87-PRO ATX LGA1150
Memory
Corsair Vengeance 8GB (2 x 4GB) DDR3-1600
Storage
Samsung 840 Series 250GB 2.5" SSD
Seagate Barracuda 1TB 3.5" 7200RPM
Video Card
EVGA GeForce GTX 780 3GB
Power Supply
Corsair 750W ATX12V
Thank you so much
its enough... if you dont plan on overclocking, as it is a 'k' unlocked processor.
it will run very high temps but if you have good airflow it should not throttle under heavy extended usage.
but intel include it in the box with it because its good enough to do the job as stock, just upgrade cooler if u want to overclock
Thank you so much, the only reason I got the K version is because the tiny bit of price difference and for now I have no plans of OC, just future proofing my build :)
