G Guest Guest Apr 17, 2016 #1 Idle temps are around 27-35C. And while full load it maxs out around 65-70C. Is this better than normal for this chip, or is this a pretty normal over clock?
Solution nitrium Apr 17, 2016 Didn't you effectively ask this same thing here? Two people already told you that was a good OC for that CPU. How many do you need? http://www.tomshardware.com/answers/id-3034718/good-volts-clocking-4790k.html#xtor=EPR-8809
nitrium Distinguished Jul 27, 2009 1,576 104 20,690 Apr 17, 2016 Solution #3 Didn't you effectively ask this same thing here? Two people already told you that was a good OC for that CPU. How many do you need? http://www.tomshardware.com/answers/id-3034718/good-volts-clocking-4790k.html#xtor=EPR-8809 Upvote 0 Downvote Solution
A axe41031 Reputable May 25, 2014 57 0 4,640 May 3, 2016 #4 That's a good temp. my friends 4790k runs at 63c at 4.4ghz (he uses a hyper 212 cooler), so you are doing great. Upvote 0 Downvote
