Good evening,
I really hope I will receive some help as im honestly hopeless on what to do at this point. I am really grateful for those that will help.
I have been reading through many articles all throughout the past two years.
Short story:
I bought this PC it was in a mini atx case and had a corsair h55 cooler, from as far I can remember it was fine the temperatures everything.
Then two years ago I use to get random frame freeze, sound would work or cut out and the screen would be on the last frame. It would be impossible to go to the task manager or anything like that.
Short fix would be to force power off, turn it on and it would be good again. At first it would happen once or twice per week. Then it became frequent, I started messing around researching threads. As far as I can remember I fixed it somehow it was not happening. I also invested in a massive corsair 4000x case as well as 6 corsair fans in hope that this would help. I moved back three days ago, it would happen every 30-40min. Therefore I started reading threads that always say the AIO is dead, so sure thing I invested in the corsair h150i cooler which I managed to mount today. Just to find out that the pc starts to a "HIGH TEMP ERROR" it would be 80c in BIOS. I have booted it now and I think it is down to 60-70c idle.
Problem in short:
I7 4790k is 80c idle
and 100+ when tasking (I use to think the sensor might be dead and always carry on doing my things until it would crash)
Things I tried:
Bigger PC case
Repositioning fans
Bought a new AIO cooler
My specs:
I7 4790K
GTX 1080
MAXIMUS VII IMPACT
Maybe a problem with voltages? I am not sure which ones to set, I have tried auto but maybe something is not right? I heard people had problems, the bios is very confusing for this mobo as it has many tweaks.
I have an exam presentation to post really soon and therefore I hope I can finally resolve this after throwing in quite a bit of money buying parts that essentially made it worse.
Thanks once again.
Short story:
Problem in short:
Things I tried:
Bigger PC case
Repositioning fans
My specs:
I7 4790K
GTX 1080
MAXIMUS VII IMPACT
Thanks once again.
