My parts are as follows:
Fractal Define R4, a special version which has more insulation, the top and side fan mounts are closed. One 140mm fan at the front, one 140mm fan at the back.
MSI 970 4G, it doesn't run the fan at idle.
G Skill 2133 MHz CL9, which also runs at that speed in the bios.
ASUS Z97 Pro
i7 4790k, stock speeds, turbo mode at 1.168v
BeQuiet Dark Rock 3
Seasonic X 650 in Hybrid Mode
I'm measuring the temperatures with RealTemp 3.7 and CPUID HWMonitor, I'm monitoring the fan speeds with ASUS Dual Intelligent Processors 5, Temps are off by 10°C under load.
Temperatures are as follows:
Idle
CPU 35-50°C at 450rpm to 600rpm, CH3&4 500-600rpm
Motherboard 32°C
GPU without the Fan an is around 40-50°C
Load, I encode a file with Handbrake which sets the cpu usuage to 100%, I ran the test for 3mins.
CPU avg 70°C at 1230 rpm Max was 76°C. The rpm as well as the temperatures are a bit off in the ASUS suite, 100% is set at 2200 rpm. I guess that the real max of the cooler is 1400 rpm at that speed.
The other temperatures stay the same while testing.
I did the same test with all the 3 fans at 100%, it is only a 2-3 deegrees less on avg.
While gaming I get 60-70°C and at fans 100% 50-65°C.
I expect the temperatures a bit higher because of the insulation of the case and the low fan speeds that I set. However I'm still a bit worried whether those temperatures are alright. I have checked the cooler twice, in fact I unmounted it and tighten all the screws, checked the thermal paste and everything seemed alright. The cores run relatively even on temperatures, all are within 1-2°C, Core 0 is the exception with about 3-4°C.
I know that everything under 80°C is fine, but I still expected it to run a bit cooler. I appreciate all advice.
Thank you
ASUS Z97 Pro
BeQuiet Dark Rock 3
Idle
Motherboard 32°C
Thank you
