Hi there! I just got a Samsung 850 evo 250 gb and i installed it on a Asus N552VX laptop, replacing a toshiba 1tb 5400 rpm hdd. Doing so, i did a win 10 clean install on the ssd and updated the usual drivers.
Now for the differences i cannot explain: i use this laptop for some light gaming, like dota 2. So then i go on and try it, to my big surprise the cpu temps rump up in a minute or so and so does the fan speed (i used to have those temps and fan speed after, like, 2 hrs gaming before).
First steps i've taken from there?
-check again gpu drivers, updated (worth noting i used DDU right after the win 10 install to start fresh with the gpu drivers, a mistake?, i dunno really)
-go to Asus support and see if there was anything useful for my laptop model, so i:
*updated the bios
*installed Intel Dynamic Platform and Thermal Framework Driver
*installed Intel INF Update Driver
Nothing, the situations stays the same.
Now for some temps:
-idle cpu 20-30 celsius degrees
*after 2 mins in game cpu goes 65-70+ degrees celsius
-gpu 50ish degrees 2 mins in gaming
-ssd about 30 degrees idle and gaming too
The change in cpu temp is not abysmal (less than 10 degrees) since the clean install, but the way it gets there is totally different.
before it was a sort of spyke temp after long gaming (same goes for the fans) now is a stable temp from the very beginning (same for fans speed).
I think its all for now.
other specs:
intel i7 6700hq
gtx 950m
8gb ddr4 ram
Thank you very much for your help!
*updated the bios
Now for some temps:
other specs:
intel i7 6700hq
gtx 950m
8gb ddr4 ram
