[SOLVED] i7 6700k idle temp changes and max temps changes
Feb 2, 2019
22
im having some problems with getting my i7 6700k cpu to idle correctly. sometimes it will seem fine and other times it will idle really high. i have no clue whats going. any help will be apreciated
unless my corsair cooler is going out i dont know. this has happened alot of times now. but it has fixed itself in the past. i have changed the heat sink 3 pin connector to another header before and it went back to normal. which now isnt doing that just same thing high temps. bios fans are set to full. and i use icue program to control my corsair cooler
