J Jonofre Honorable Feb 27, 2017 16 0 10,510 Aug 11, 2017 #1 I've been looking into upgrading my i5-6500 to a i7 7700 non k, Im not sure if i should invest in an aftermarket cooler or is the stock cooler with the i7 enough?
Solution amanchandra Aug 11, 2017 Please invest in an aftermarket cooler, as the intel's stock cooler is not that good enough, especially when comparing with Ryzen's Wraith coolers. You can go for the cheap and best Cooler Master 212 EVO https://www.newegg.com/Product/Product.aspx?Item=N82E16835103218&cm_re=cooler_master_212-_-35-103-218-_-Product Currently the LED version is on sale, so go for that one if you have a tempered glass panel. Or if you want an AIO Liquid cooler, go for Corsair Hydro Series H100i https://www.newegg.com/Product/Product.aspx?Item=N82E16835181103 All awesome. But do remember with intel i7's, it's a general rule to buy a cooler.
JackNaylorPE Titan BANNED Oct 30, 2004 32,255 14 99,960 Aug 11, 2017 #2 Yes, if it wasn't, they'd have a helluva lot of warranty issues to deal with. As long as you not sitting in desert @ equator you shud be fine Upvote 0 Downvote
amanchandra Honorable Oct 10, 2013 88 0 10,660 Aug 11, 2017 Solution #3 Please invest in an aftermarket cooler, as the intel's stock cooler is not that good enough, especially when comparing with Ryzen's Wraith coolers. You can go for the cheap and best Cooler Master 212 EVO https://www.newegg.com/Product/Product.aspx?Item=N82E16835103218&cm_re=cooler_master_212-_-35-103-218-_-Product Currently the LED version is on sale, so go for that one if you have a tempered glass panel. Or if you want an AIO Liquid cooler, go for Corsair Hydro Series H100i https://www.newegg.com/Product/Product.aspx?Item=N82E16835181103 All awesome. But do remember with intel i7's, it's a general rule to buy a cooler. Upvote 0 Downvote Solution
