Hello!
I was hoping to get some help with an recent issue that has come up on my i7-7700k desktop (full system build below).
The system is just about 2 years old and has been running fine until about 5 days ago. I started noticing some graphical glitches while playing a game and, when checking the temps, I noticed that all four cores were hot and that core 3 had logged. I got everything shut down right away so it could cool. Then I went to work inside the case. I checked all of the filters and fans for dust, cleaned the heatsink, reapplied thermal paste and installed a brand new Noctua fan on the radiator.
Upon rebooting, the temp readings on the CPU are still too hot for my liking. I am seeing idle temps that bottom out in the mid 40s, but typically fluctuate between 50 and 60c. Light loads bring the temps up to 70c or more. I am getting temps from three different programs; each a bit different in terms of readings so it is hard to get exact temps.
Below are two screenshots showing speedfan, HWmonitor and realtemp. During one capture, I was running GTA5 and OBS to capture video (which I can post if it would be helpful to see the fluctuations). During the other capture, I had opened a number of programs to push the CPU load to max.
Temps during GTA5
Temps during max load
One thing I noticed - the load indicator from HWmonitor and RealTemp are very different.
What I have done:
Cleaned the case and checked airflow
Confirmed that the fans work and appear to be spinning up, though the CPU fan never seems to hit maximum RPM
Removing heatsink, cleaning, reapplying thermal paste and re-seating the heatsink - twice
I was hoping some of the experts here could weigh in and let me know their thoughts! Are these temps normal? Should I be worried about the fluctuations at low loads. I know that the 7700k's tend to run hot, but the overheating and recent heat issues in general are a brand new issue for me.
If you need any more information of if a video showing the fluctuations would be useful, please let me know!
Thanks for reading!
Elader
Full System -
Intel i7-7700k
Coolermaster Hyper 212 Evo cooler
MSI X270 Gaming Carbon
16 GB RAM
250 GB SSD
3GB Data Drive
Geforce GTX 1080 Windforce OC
EVGA Supernova 750w Power Supply
Coolermaster Storm Stryker case
Temps during GTA5
What I have done:
Thanks for reading!
Elader
Full System -
Intel i7-7700k
16 GB RAM
250 GB SSD
3GB Data Drive
