Recently build a PC with i7 7700K, Asus Z270F mobo, H100i V2 Liquid cooler, Corsair 570X cabin
My mobo has AIO PUMP Header. So, i plugged H100i V2 pump connection in it.
And Both stock fans of H100iV2 into CPUFAN, CPU OPT Fan headers & CLink into usb 2.0 header.
Its fixed on the top of case. Fans below the radiator.
Tweaked fans to max & pumping speed to max.
Everything OK except temps.
Temps are like this:
42-50 in normal
upto 70-75 in gaming
Changed the connections , Pump conn to cpu fan header and fans to liquid cooler connections itself. No change in temps.
I didn't used external thermal compound.
Any solutions are appreciable .. Thanx..
42-50 in normal
