Hi
I purchased a Cooler Master MasterLiquid Lite ML240L All in one watercooling Dual fan system from PBtech to cool an i7 7800k. In BIOS temps would idle around 42-43C so I got it replaced under warranty as forums are saying 25-30C should be what idle is.
The replacement does exactly the same.
Running the fans on full from the BIOS don't change the temp, running then on silent and the temp goes from 42 to 43-44.5
Any thoughts are welcome, temps over 40C idle bug me seeing at my i5 6600 sits at 25-28 on air. (Motherboard is ASRock Z370M)
