Hi,
Not long ago I decided to replace the thermal paste on my I7 920 heatsink, with the artic silver paste in hope of reducing the temps. Sadly the cpu became hotter (idle: 50-55, when playing demanding games it can reach 70 degrees, but it usually stays in the mid 60's), so I made sure that the fan was placed properly and reapplied the paste several times. It is overclocked but I haven't increased the voltage and hyperthreading is disabled.
Before I applied the thermal paste the cpu had an idle temp of 40-45, not sure what is was under load but it was probably lower as well.
My suspicion is, that the the heatsink/fan is not working as it should, it's the stock I7 cooler btw.
So does anyone think that might be the problem?
I'm sure it has nothing to do with airflow or ambient temp (it's 28-30 usually when idling), and my Gigabyte 560 ti runs with 28-32 degrees idle.
I have also noticed that the cpu's AUX temp is 80 when idling.
