Hardware specifications:
Problem description:
Hello. 4 days after installing an SSD and updating the BIOS on my new pc, I started having a lot of trouble with overheating. At idle (1-2%), my CPU is around 34-36°C, but during a bit higher loads (3-12%) the CPU can get as hot as 60°C, and at even higher loads (30%+) it can get as hot as 80°C. After running a stress test the temperature reached 100°C, and dropped down to the 30° range in about 2 seconds after the test ended, this leads me to believe that the cooler is working but not efficiently enough.
At first I thought that I accidentally bumped my CPU cooler causing air to get in between the cooler and the CPU drying up the thermal paste, however, this does not seem to be the case since cleaning/reapplying thermal paste has not helped.
After browsing around the web for some time, I suspect that the problem could be with the voltages delivered to my CPU, one user in a similar thread on this forum suggested to watch JayZ's videos about underclocking, but I have not been able to adapt the information conveyed in them to my specific problem, so I was wondering what you think the problem could be. Please see the included image from the gigabyte control center displaying CPU voltages, one thing I noted is that the clock frequency (and perhaps voltage) seems a bit high for such a low CPU load.
All ideas and advice are appreciated, please excuse any grammatical errors (english is not my first language).
Kind regards.
/Elias
CPU | Intel Core i9 12900KF 3.2 GHz 30MB |
Motherboard | Gigabyte B760M DS3H AX DDR4 (BIOS = F15) |
CPU cooler | be quiet! Pure Rock 2 |
PSU | MSI MPG A850G PCIE5 850W |
SSD | Kingston NV2 M.2 NVMe Gen 4 2TB |
Thermal paste | DeepCool Thermal D9 |
Kind regards.
/Elias
