[SOLVED] i9-9980xe and 4133Mhz DDR4, Compatible?
eddiegnz1
Commendable
Jan 27, 2018
Is the i9-9980xe compatible with DDR4 memory if the memory is 4133Mhz?
This questions the 4133Mhz speed of the RAM because each stick is 16GB.
Proposed system for TV broadcast editing;
  • CPU; Intel i9-9980xe
    RAM: Corsair DDR4 4133Mhz (8 sticks of 16GB per stick = 128GB total)
    MoBo: Asus Prime-x299 Deluxe II
Motherboard supports that speed so it should work, just enable XMP in the BIOS to get it to run at the correct speed. Even it's it's not on the QVL it doesn't mean it won't work as Asus doesn't test every kit out there, just a handful.
