IA-64 vs x86-64/x64. Help me settle a debate.
atomicWAR
Glorious
Ambassador
So not to skew the answers I won't tell you what I think vs what the other person thinks. This is the short of the debate.
Is Intel's Itanium IA-64 a x86 CPU architecture? If yes, is it a native x86 architecture (ie will it run x86 programs at full speed without emulation)?
Update: will include my opinion after 10 responses not including mine.
Updated...Any change of opinions?
Patrick Proctor Cooe • 5 hours ago
Your PC can do it through a software layer. Itanium runs x86 binaries on the hardware out of the box. And yes, it's native. It's just using different circuits from the Itanium code.
Cooe Patrick Proctor • 5 hours ago
I know exactly what you are talking about and you are still wrong. Having a few common x86 registers on die to facilitate EMULATION doesn't mean the code is executing natively. (there's just dedicated hardware to assist with said emulating, the vast majority of the x86 ISC isn't natively supported 1-1 in Itanium, there just wasn't enough room (and that would have made the chip something else entirely). As x86 and Itanium almost have...
It's not an opinion.
x86 is an implicitly sequential CISC instruction set with most modern x86 microprocessors employing a decoding layer to implement RISC logic.
IA-64 is an explicitly parallel VLIW instruction set that supports x86 through slow emulation. IA-64 instructions are compiled in bundles of 3 which are executed using VLIW-RISC logic. Furthermore, IA-64 makes heavy use of predicates at the instruction level, a feature completely absent from x86
IA-64 has more in common with AMD's HD 6000 series GPUs, and ARM microprocessors than it does with x86
I was going to wait for ten posts but at this point you all have made my point. Pinhedd you response was particularly detailed and therefor awesome. Though I thank you all though for your time and great responses!
I was saying exactly what you all have been re-affirming. They are completely different architectures. x86-64/x64 is 64bit extention of the x86 as CISC based architecture that is executed to RISC microcode on chip prior to execution; while, IA-64 was a 64bit RISC CPU that did x86 through slow hardware emulation. Or as Pinhedd stated more explicity stated "a parallel VLIW instruction set through slow emulation". Anyways thanks everyone. This was never a debate or opinion just facts. The person I was debating (nice for arguing) with said Intel Itanium was the first 64 bit x86 CPU. When I explained that wasn't true and told them of the differences between the chips and their architectures. They called it "semantics" and "splitting hairs" and claiming the Itanuim was an x86 chip because it could execute x86 code. Apples and oranges as it were.
^ oh yeah it was better tech, way better. Especially in the long term had it been adopted. Eventually The slow emulation of x86 would have been good enough or close to what native speed of x86 was when Itanium launched. It would have taken some time was all. Never debated the dude on that. He just insisted incessantly that IA-64 was a x86 CPU and the first x86-64bit, that it is not. It was really nice to have some of the best tech's I know online back up what I was saying. Thanks so much everyone. Dude prolly still thinks he is right but he is being a troll at this point or is truly clueless and thinks he knows a lot more about something he knows virtually nothing about. That's what you get in Wccftech though in the forums. There a few knowledgeable folks and a bunch of ill informed arm chair techs that have never seen the inside of a computer case that wasn't their own personal rig...and even then they may not have every opened up their case. anyways here is a peak at some of the crap he spewed...this started it
beast6228 Sup? • 2 days ago
AMD was the first to release a 1ghz processor and the first to release a 64 bit x86 processor.
Patrick Proctor beast6228 • 2 days ago
Yes to the first, no to the second. Itanium was first. It just sucked
atomicWAR Patrick Proctor • 2 days ago
Actually no. While Itanium was a 64 bit CPU, it was not an x86 based 64bit CPU (ie x86-64). Itanium was IA-64 which is a totally different arch and one of the many reasons it failed. Having no native x86 support was a big reason it didn't get the support it needed to succeed. Itanium did have emulation for x86 code and it was much slower executing x86 code because of this. Plus AMD x86-64 CPUs could run both 32bit and 64bit code natively with no slow downs in IPC which was not true of IA-64.
Patrick Proctor atomicWAR • a day ago
It was backwards compatible with x86. It just had a more complicated, headache-inducing 64-bit extension set. AMD-64 won, but it was not first
atomicWAR Patrick Proctor • a day ago
If by backwards compatible you mean ran x86 code slower, in a non-native code set then yes you are right. And I was not arguing that it came first. IA-64 beat AMD to the market by years but it's poor implementation killed it off before it really had a chance.
You said AMD love red the first 64-bit x86 CPU. That is incorrect.
I never said that. Beast6228 said AMD made the first 64bit x86 CPU. He is also correct in saying as much. IA-64 (Itanium's architecture) is not an 64bit x86 CPU, it is a IA-64 RISC CPU. Not the same. IA-64 was a RISC instruction set running on a 64bit CPU designed to run 64bit RISC code. x64-x86 or x64 was simply an extension of the CISC based instruction set of the x86 architecture to run 64 bit and 32 bit code natively at full speed. Though to be fair on the CPU side CISC are translated to RISC on chip prior to execution for x86-64 so they are still RISC CPUs. Point being they are very different architectures that cannot be treated as interchangeable and thus separate inventions. AMD did not make the first 64 bit CPU, neither did intel. MIPS did in 1991. AMD did make the first x86 based 64bit CPU though.
No, that is an argument of semantics, not substance. Intel was the creator of the first x86 64-bit CPU.
Now, I do not dispute that AMD's design was better. It's plainly evident. But Intel was first by more than 1 year.
And I'd argue MIPS didn't win the overall race. IBM did. The first MIPS64 couldn't actually manipulate data types larger than 48 bits.
History disagrees with you...
https://en.wikipedia.org/wi...
"AMD64 was created as an alternative to the radically different IA-64 architecture, which was designed by Intel and Hewlett Packard. Originally announced in 1999[13] while a full specification became available in August 2000,[14] the AMD64 architecture was positioned by AMD from the beginning as an evolutionary way to add 64-bit computing
capabilities to the existing x86 architecture, as opposed to Intel's
approach of creating an entirely new 64-bit architecture with IA-64."
This clearly states x86-64/x64 and IA-64 are completely different architectures and as I stated not interchangeable. IA-64 was way ahead of it's time and I had hoped it would win at first. Having x64 be fully backwards compatible is what sold me on AMDs implementation. Trying to say they are the same is like saying a robin and a velociraptor are the same bird species. Yeah they are related through DNA but clearly not the same species. One is a dinosaur the other is a modern bird. Sorry but I am no buying your baseless argument.
I can agree the MIPS vs IBM bit though is less straight forward then what is posted above. I only posted it to make a point. Intel didn't create 64bit CPUs first.
I never said Intel created the first 64-bit CPUs. I'm merely saying your wikipedia source is either so biased he puts booyaboo to shame or is so ignorant he/she has no business being in tech journalism.
Intel won the race with AMD on time. AMD won on quality and popularity. That is all there is to it.
So everybody but you says one thing and you say another but you must be right and everyone else wrong. Yeah sorry but not sorry. Your wrong and won't own it.
http://whatis.techtarget.co...
https://stackoverflow.com/q...
https://software.intel.com/...
https://technozeal.wordpres...
http://mikedimmick.blogspot...
They all say the same thing. IA-64 and X86-64 are radically different architectures which is all I have ever said. They all back up what I have said. things like IA-64 used emulation to run x86 code, albeit hardware emulation but emulation all the same at slower speeds as I stated. Your trying to say IA-64 and x86-64 are both apples and they are not. One is apple one is an orange as it were. They are not both native x86 architectures. This is not a debate but a fact. Proof is in the pudding and you have shown me no pudding. However I have shown you the pudding again and again and again. You just like to deny that's what it is because it would mean you're wrong. If you can prove me wrong and teach me something new, I don't know. I am happy to learn and own a mistake but you just keep spitting out vague statements on how I am wrong or the OP of a site is wrong/biased/ignorant, etc. Show me proof not opinions and conjecture.
Patrick Proctor atomicWAR • 13 hours ago
You're splitting hairs is all I'm saying. Apple's ARM cores are radically different from the stock A57/72, but they are ARM through and through. Itanium and AM64 both ran x86. They are both x86. Only the 64-bit portion of them was not x86, and AMD's design (instruction set) won the popular vote.
Anyways that is not every post but the biggest portion of the back and forth. Thanks again for all your help!
Ask him for his sources. Why should you have to cite sources to prove your point when he doesn't provide any proof of the accuracy of his assertions?
I don't agree that we'd be in a better place had IA-64 trumped x86-64.
The trouble with IA-64 is that it's a real bastard for compilers to optimise. Despite extensive investment by HP and Microsoft, efficient IA-64 compilers just never materialised.
Furthermore, x86-64 as a standard compiler target depreciated most of the CISC instructions in the x86 instruction library. While these instructions still exist, they're decoded into microcode and executed rather slowly. Modern x86-64 machine code has a distinctly RISC look to it.
Yeah that was some of the crap I left out. But I made the point I had sited source after source only to get vague statements and opinion about how I was wrong or splitting hairs. Dude clearly doesn't know much about CPU architectures. I mean I am no uber expert myself but i know the basic differences between x86, ARM, SPARC, PowerPC, IA-64, etc. He obviously does not. And he couldn't site sources because there weren't any AFAICT.
I know exactly what you are talking about and you are still wrong. Having a few common x86 registers on die to facilitate EMULATION doesn't mean the code is executing natively. (there's just dedicated hardware to assist with said emulating, the vast majority of the x86 ISC isn't natively supported 1-1 in Itanium, there just wasn't enough room (and that would have made the chip something else entirely). As x86 and Itanium almost have nothing in common aside from common quirks after Intel got IA-64 from original dev. HP, (IA-64 has more in common with VLIW arch's like AMD's TeraScale GPU's than x86), most x86 instructions still have to been converted into IA-64 code in order to be able to execute, leading to an often significant performance penalty when running native x86 code/software (and cause re-writing all your software for a niche instruction set as both Intel & HP had intended (the emulation shenanigans were just a shoddy stop gap solution) is crazy expensive, is a big part of the reason Itanium failed.
No, you didn't have to convert any part of the binaries at all. I am dead right. Go ahead and break the contradiction. Your standard says there is no x86 64-bit CPU at all. Nothing natively runs x86 anymore. So either it's neither, or it's both.
Cooe Patrick Proctor • 4 hours ago
Lol on further research it turns out we're both right in ways actually, you're correct on that it actually was technically the first 64 bit x86 chip (though only on paper, no-one was using them to run x86 code, as other x86 chips of the era could run it faster). The very first Itanium chip did include enough of the x86 ISA in hardware to be able to run native x86 binary's (though again, nobody did). But I was right in that Itanium ALSO used binary level ISA emulation to execute x86 code. Turns out after that first chip, they scrapped the dedicated x86 hardware entirely and switched to an x86 to IA-64 binary translator/re-compiler called the IA-32 Execution Layer that did precisely the kind of ISA binary emulation I was talking about and was precisely what I was thinking of. Easy to see how we got confused when we both had correct information, just not at the same time hahaha. I just had absolutely no idea it wasn't like that throughout the entire Itanium line, so I'll be darned haha. And you are totally correct in that most x86 instructions aren't explicitly located in hardware on modern x86 chips, but rather in microcode for all sorts of obvious reasons (like die space o' course haha).
Patrick Proctor Cooe • 4 hours ago
As I said, two very different approaches to the problem, and both were equally x86 at the outset.
I get a bad rap because I can actually argue. I'm not out to troll (usually, though when I do it's damn obvious) or attack people. I know what I know, and I prove what I can prove.
Now, back to dealing with the anti-HMC crowd...
Maybe. Seems more like your clinging on to an argument that is lost. Hardware emulation is not native x86. No matter how you slice it. I was clear from post one I was talking native x86. Now I can see where in your head that is splitting hairs, sorta. IA-64 did have hardware emulation, not software. Ok MAYBE. But beast was specific he said AMD made the first x86 64bit CPU. No mention of emulation, it was a native x86 CPU instruction set he spoke of. If anything you are the one who split hairs right then and hoped no one would notice, but I did and I called you out on it. You might want to call facts semantics because they don't suit your argument but that doesn't make them any less facts. One of those links I included was from Intel, the horses mouth. Intel does not consider their own IA-64 a x86 CPU. They consider it an IA-64 CPU with hardware emulation for x86 that by their own admission doesn't run full speed (the definition of emulation, running software designed for different hardware while not running full speed). So by your argument Qualcomm's ARM chips that run x86 through emulation being co-developed by Mircosoft as also x86, even though they are not. They are ARM. And before you say "oh they are using software emulation"...It is still emulation which the IA-64 uses, different implementation granted. And who would be splitting hairs then? Just own it. You are wrong. Be an adult not a troll!
Cooe atomicWAR • 5 hours ago
Haha I replied almost the exact same thing above before I'd read your last two posts of the sub-thread and discovered you'd beat me to it. Touche 😉.
atomicWAR Cooe • 2 hours ago
Thanks for the back up. I never said all his point were wrong but he wasn't, until very recently, using any logic besides "I am right, everyone else is wrong". No facts just insistence. His arguement as improved but for me it still doesn't make the leap he is trying to say it does. IA-64 is not x86. yes IA-64 had some commonalities. But one big thing is it didn't run full speed x86. It always had to be run at a slower mode. For me this is the crux of the argument. If IA-64 could run x86 full speed in hardware and using microcode, then I wouldn't have as much of a leg to stand on. The fact is as far as i can tell/know. It can't. And that is where his argument hits the wall. It also should not have taken this much back and forth for him to actually state some substance over opinion. I gave him substance from very early on and kept getting "but I am right and you are wrong" with no supporting facts. For a debate to be just that, you need facts. At least he got there eventually. Again still not enough in my book but a much better argument on his side.
Cooe atomicWAR • 2 hours ago
Turns out we were mostly wrong on that point (as you can see from above posts) I found out from further research. The very first Itanium chip DID include complete x86 hardware support that could run x86 code/binary's natively just as it could IA-64. It wasn't till the 2nd gen that they realized no one was using all that hardware, because other x86 chips of the time were faster for x86 code (it being 64bit had no beneifical impact on running 32bit x86 code), and stripped it out and replaced it with the emulation stuff (which stayed for the rest of it's life), which is all I knew about, so I agreed with you. But in actuality the very 1st Itanium chip was a native x86 chip that was 64bit in design (it was essentially a dual ISA chip believe it or not, native in x86 & IA-64).
Sources? Just want to see for myself. Always willing to own a fault if it is mine to own but also need to see proof first hand.
https://www.cnet.com/news/i...
Just one of many when I actually went looking. Actually found a fascinating Intel quote from when they were just getting into it with HP that having it be able to run both IA-64 and x86 code natively was required for Intel to jump in (would have to go track it down again though haha). This one makes the point of why the native x86 hardware was removed. It wasn't any faster than competing, only x86 chips. Intel even believed, or at least said they did (at the time) that IA-64 was fast enough to be able to emulate the x86 code faster than the native hardware processed it, hence the switch with the 2nd gen onwards (I imagine this didn't really pan out in reality though lol, IA-64 was kind of crap, and so was Itanium's performance running it (though better than it running native x86, but better enough to be able to emulate x86 and come out on top? Nevermind.. just looked it up. This is true also. The native x86 binary readable (aka it could execute the native binary x86 code/instructions) hardware was SLOWER than the binary x86 to IA-64 translation emulator they made. Wowza. Talk about first, but last hahaha.
atomicWAR Cooe • an hour ago
Yeah that article is a bit vague and if I understand it correctly only restates what I have said. And as far as I can tell it is refering to the hardware emulation I spoke of. Check this quote out from another piece...
"Compatibility with existing x86 applications was a concern in the
IA64 ISA, but not a priority. The ISA specified a mechanism for running x86 programs in hardware, but the chip was optimized for the native ISA, and x86 execution was not to be at-speed[21]. Jeff Havens explained in a personal interview that the goal was to run x86 software as well as the previous generation of contemporary x86 processors. In fact, this goal was never met, and the x86 hardware emulation was eventually removed. Instead, it was replaced by a binary translation mechanism to convert x86 programs to native IA64 code. Havens recalled that the Intel team reported comparable performance using binary translation, and that this was the point at which hardware emulation was cut."
This is what the cnet article you used as evidence refers to. And as I pointed out very early on, this is not native x86. Yes some of the circuitry was there but not in total nor did it run at full speed as I stated. This does not qualify as native x86 IMHO. here is the article is it's totality.
http://courses.cs.washingto...
Cooe atomicWAR • an hour ago
This is all true, though they are using a different form of the word "native" in this context to mean it's primary ISA, but It's still a native x86 chip just as much as it's a native IA-64 chip, as far as instruction support and native code execution, and that's all that matters. It can process both instruction sets/ their binary code (aka no conversions taking place on the data in any way shape, or form), 110% natively. That's an immovable fact. Whether the native x86 side of the chip sucked crap through a straw compared to the more important, primary portion of the chip handling native IA-64 code doesn't make it any less of a true, native x86 processor no matter how badly that sits with you. Native instruction execution (NO MATTER HOW SLOW) is all that matters for that qualifier, and that's just the freaking definition of the term. A chip belongs to a certain ISA if it can natively execute those instructions in hardware. This most definitely can. x86 chip? heck yes, good x86 chip? heck no.
Yeah I have to disagree. This is not about how it sits with me but how code is executed. Hardware emulation, is still emulation and therefor not native. The definition of emulation is to run code that IS NOT NATIVE to the instruction set. There is no way around that bit. I have always said IA-64 was capable of running x86 code, just through emulation. This argument only strengthens my stance, not weaken it. And again this is also running the code at a slower speed, again not native. If it ran full speed then another one of my legs would be gone because his argument about CISC running on RISC through microcode would hold more merit. But the short of it is the Itanium never ran x86 code at full speed. While I appreciate you trying to bridge the gap and see both sides, things I admire in any debate, it doesn't change how the code was executed. At the end of the day IA-64 had to use emulation not native code execution.
You don't understand the word "emulation" at all. It MEANS converting binary code from one CPU's ISA to another, LITERALLY, as in from my freaking CS textbooks. That's not happening here, the x86 code isn't changed at all lol. And at no point is such a process (or anything analogous) occurring at any point in the x86 execution hardware, the instructions are executed as x86 instructions, on x86 hardware, which from then go to any shared hardware they might need to use (with the IA-64 execution hw, which is completely inactive this entire time because absolutely 0 IA-64 instructions have been processed). It was closer to a dual-arch/ISA frakenchip, heavily weighted in one direction, than anything else.
I do understand emulation (different words used but we were saying the same thing), I'll give you if the code is not changed at all it is not emulated but I am still waiting on the broken link to read up on before making further comment.
https://techterms.com/defin...
Everything I was saying is there though I should have left speed out in the strictest terms of the definition though usually slower speed is part of how emulation plays out. However in theory if you system is powerful enough you could emulate software at the same speed as the native system though it is near impossible to do this (with the same generation hardware/ hardware made in the same years time) without some type of slow downs which was why I used a looser definition of the term.
It does both natively. From wiki's binary translation article (https://en.wikipedia.org/wi...
- "Intel Corporation developed and implemented an IA-32 Execution
Layer - a dynamic binary translator designed to support IA-32
applications on Itanium-based systems, which was included in Microsoft
Windows Server for Itanium architecture, as well as in several flavors
of Linux, including Red Hat and Suse. It allowed IA-32 applications to
run faster than they would using the native IA-32 mode on Itanium
processors." And there's far more out there to back up it's native x86 execution abilities (no matter how freaking terrible they were).
This one has a broken link so i need a bit more to comment on it directly
As far as I can tell this changes nothing but please chime in if i am wrong.
