EDIT: I have found that HWMonitor properly displays the offset! This seems to be a bug with HWiNFO on some Legion laptops! See here:
_______________________
Original post:
This is a problem that I am seeing repeatedly asked, but no true solutions have been given:
forums.tomshardware.com
I have my Legion 7i, i9 14900HX, I have changed the necessary BIOS settings, I have uninstalled Lenovo Vantage.
If I change the CPU Core Offset Voltage in Throttlestop, it shows up as properly working in the Throttlestop window.
However, in HWiNFO (of course, I restart it), it ALWAYS shows 0.098 for IA voltage offset. (however, undervolting the cache displays as working fine in HWiNFO)
What is going wrong here?
I have tried rebooting, making sure Throttlestop runs first, deleted my Throttlestop settings file.
All necessary settings such as Undervolt Protection are properly set in BIOS.
Uninstalled Vantage, and do not have Intel XTU.
mvboost is NOT enabled in throttlestop.
Thank you for any help.
Original post:
Question - IA Voltage Offset is different, while P and E cores reflects the undervolted voltage ?
Laptop is a Lenovo Legion 5i Specs i7-14650HX 4050 6gb 32gb ram 1TB ssd 80wh Li-Po IA Voltage Offset is different while P-cores and E-cores reflect the undervolted voltage. Is there anything wrong? Settings I changed: For High Performance (Plugged In) Speed Shift : On Speed Stop : Off CPU...
