Hi, I've been using the server in the title as an everyday use PC. I installed Linux on it, and the power settings were that after 30 minutes, the machine would suspend.
The problem is that now I can't seem to turn it on again.
I've removed the BIOS battery, removed the jumper that's right beside it, swapped the ram and the HDD and no matter what I do, it won't come up again.
Usually, when I remove the power from the PC and then plug it back, the fans would come up at high speed and after that the BIOS would kick in.
Now, the fans do spin but at lower speeds, like when I turned it on without removing the power.
I don't know what else I can do
