IBM ThinkPad T41/T42 Wireless Problem
wcstech
39
Here is my situation:
I have received 4 T41 and 1 T42 laptops from a MS authorized refurbisher. Upon initial boot, they boot like brand new out of the box machines. I set them up for our network and install software needed by our organization. On first setup, the Windows XP detected area wireless networks and I was able to connect them to our network wirelessly. After a few days however, when I try to list the available wireless networks I get "No wireless networks were found in range". The odd part is that they remain connected to the wireless network I connected them to when I set them up but to switch networks (say between work and home) is not possible because no wireless networks (even the one they connect to automatically) show in the wireless networks list. All 5 of them do this so, I can only assume this is some kind of problem with Windows XP or the laptop. I have tried the following to fix this situation to no avail:
1. Reinstalling the adapter driver with a more current version from both Intel and Lenovo. The Intel one says there is no compatible wireless device (though I downloaded and installed what they say to for a Intel PRO/Wireless 2200bg) and the Lenovo one says the driver I already have installed is more current though the dates on the download say otherwise).
2. Reinstalling XP SP3.
3. Trying the adapter drivers for every type of adapter the T41 ever came with thinking the wrong adapter type had been identified by the refurb company.
4. Installing various 3rd party wireless network management software (including IBM Access and LucidLink). They do not work properly for some reason.
5. Installing Microsoft Hotfix KB942288-v3-x86. This works briefly. I install it, restart the computer, the networks list fine, but then a day or two later they are gone again and I'm back to square one. Reinstalling the patch may or may not work again temporarily but does not provide any kind of lasting solution. I've done this by trying both just the patch and then trying the patch and reapplying SP3 after the patch. Neither works permanently.
6. I have tried installing an external USB wireless adapter and it does not work either. Same thing, says there are wireless networks available but when I click to list them the list says there are no networks in range.
7. Uninstalling the adapter and letting Windows reinstall it. It identifies it as a Intel PRO/Wireless 2200bg and installs a 12/2007 dated driver.
8. Making sure the wireless signal is on.
9. Disabling any power saving settings that may be putting the adapter to sleep.
I do not believe this is hardware related as the adapter works fine as far as connecting and picking up signal and other adapters do not work either. It is just that the software does not show the networks available.
Additional ideas from what I've already attempted would be greatly appreciated. It is not an option for me to replace these things for another 2-3 years and I'd really like to be able to give my employees something they can actually use on a portable basis outside our building.
I have had little success in finding someone else with this problem. I've been searching for a year for a solution and no one else seems to have this problem which I really find hard to believe since I have 5 of them that do this it can't be an anomaly to me and I can't believe I am the only person still using T41s/T42s out of likely thousands of them that were ever made.
wcstech, I had exactly the same issue as you on my t42 for months [actually used a 3rd party wireless manager to get around it but was not happy with that]. Searched for a solution, found your thread, applied the fix from MS with no success. Finally in desperation [as I cannot roll this machine back to SP2] just removed all of the network devices from device manager, rebooted and BINGO it works fine....have you tried that?
