A pair of compact coolers give system builders OEM alternatives.
Iceberg Thermal IceFLOE T65 and T95 Review: Small System Cooling : Read more
The Author's test methodology is correct.Also no AVX? That's weak. Leave the CPUs at stock, sure, but let them stretch their legs to the fullest to see if this actually an adequate cooling solution.
Prime95 Small FFTs (all AVX test selections disabled) is ideally suited for testing thermal performance, because it conforms to Intel's Datasheets (see page 90, section 5.1.1, 1st paragraph, 2nd sentence)as a steady-state 100% TDP workload with steady Core temperatures. No other non-proprietary utility can so closely replicate Intel's thermal test workload, however, OCCT Small Data (Steady Load), SSE Instruction Set is very nearly identical.
When heavy "real-world" AVX workloads are at "peak" load, such as video transcoding apps (which are fluctuating workloads), the workload will typically approach, but not exceed P95 Small FFTs without AVX. The CineBench R23 CPU Render Test shown below is a good example of a utility which replicates real-world AVX transcoding workloads. Prime95 Small FFTs (all AVX test selections enabled) is nearly a 130% workload, which is unrealistically higher than real-world AVX workloads.
CT![]()
