IDE extension cable/adaptor
G
Guest
Guest
Archived from groups: alt.comp.hardware.homebuilt (More info?)
OK, here's the problem.
I want to mount an IDE drive in a locked box outside the computer.
In order to be able to move the computer ( or in the event of theft? )
I need to find some way of having an ide cable connector outside of
the computer case - so that the IDE cable coming from the mo'board can
simply be unplugged without having to access either the computer
internals or the secured hard drive.
The thinking here is that if someone's gonna pinch the compy, they
probably won't have the nous to realise the HD is externally mounted,
or the time and kit to hack open a small safe.
It occurred to me that what's needed is an IDE extension cable ( i.e.
female on the mo'board end, male on the other ) or an adaptor to
bridge two standard ( female to female ) IDE cables together.
But can I find one?? Nope - or at least not one that's ATA66/100
compatible.
Anyone know of a likely source in the UK ,or even something that could
be adapted ( such as an ide back/front plate ) ??
I tried fiddling about connecting two IDE cables together with brass
pins..but it doesn't work.
Serial drives aren't an option - as yet.
Cheers,
Stephen Howard - Woodwind repairs & period restorations
www.shwoodwind.co.uk
Emails to: showard{whoisat}shwoodwind{dot}co{dot}uk
"Stephen Howard" <seesigfor@email.uk> wrote in message
news:tt08b19o1psbh9ge02tdljpti7puug6llg@4ax.com...
> compatible.
> Cheers,
There a a couple of options that may be feasible for you.
1. Use the IDE disk in a removable caddy, something like this
http://www.savastore.com/productinfo/product.aspx?catalog_name=Savastore&product_id=10214024&pid=206&rstrat=3187
..When the disk needs to be secured remove from caddy and place in a safe or
take it with you.
2. Use a SCSI disk, an adaptor card such as the 2940UW allows the fitting of
an external drive to its external connector.
MJP
Stephen Howard wrote:
" It occurred to me that what's needed is an IDE extension cable ( i.e.
female on the mo'board end, male on the other ) or an adaptor to bridge
two standard ( female to female ) IDE cables together. But can I find
one?? Nope - or at least not one that's ATA66/100 compatible. "
IDE cable length wasn't really a problem at ATA-33 speeds. As the
external bus speed increased, it was noticed that any cable over 18
inches in length gave rise to corrupted data upon transfer. That's the
reason you won't find ATA-66/100/133 extension cables. You say that
SATA is out of the question, so your best bet is to look towards getting
an external USB hard drive.
Get an IDE/USB adapter. You can run a hard drive via a usb port. I
found these on ebay, I'm sure they are elsewhere.
Try here:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=42322&item=6778682368&rd=1
Hope this helps.
DRG
P.S. This is not my auction nor have I ever used one of these.
> compatible.
> Cheers,
>Try here:
>Hope this helps.
>DRG
Cheers for the suggestions so far:
The 18" boundary isn't a problem, it's plenty long enough for my
purposes - I just need to be able to split the cable in two.
I considered scsi - and I've got plenty of adaptors spare ( no decent
drives though ), but then if I was going to invest in a new drive I'd
probably go for Serial and get an adaptor ( trying to keep it cheap!
). I'd still need a split cable though.
I already use removeable caddies, but only for backup - the idea
behind this project is to cut down on faffing around whilst still
enhancing security.
I'm a bit sceptical about the USB solution in terms of speed - would
it match ATA66 throughput? If not, I might as well run the drives on
40 strand cable.
Can such drives be bootable also?
Regards,
why not try an external hard drive with both firewire and usb2,
that way you can have the best of both worlds.
the other option i would suggest is using a network cable with
and set up a nework storage device at the other end.
cheers.
p.j.
news:b588b1tl5uvptj6pojbhbjghtoq19am96s@4ax.com...
>>Try here:
>>Hope this helps.
>>DRG
> enhancing security.
> 40 strand cable.
> Regards,
In article <42b44755$0$11351$5a62ac22@per-qv1-newsreader-01.iinet.net.au>,
>cheers.
>p.j.
>>>Try here:
>>>Hope this helps.
>>>DRG
>> enhancing security.
>> 40 strand cable.
>> Regards,
You can get a SATA control card that gives your a SATA connector on
back panel. There are also SATA backpack enclosures.
a d y k e s @ p a n i x . c o m
Don't blame me. I voted for Gore.
