IDE to USB help please
Nightmare515
55
Hello all,
I have an old IDE drive that I'm trying to get the data off of. I have a UDE/SATA to USB adapter that I'm using.
The adapter is perfectly fine, it powers up the IDE CD drive that I used to test it but it simply will not connect my IDE hard drive to my computer. It also powers up internal SATA drives that I pulled out of my laptops just to check.
The IDE drive shows up in device manager as WD800 drive but under disk management it shows the drive as "No media". I have assigned multiple different drive letters to it but nothing works.
I have used Easeus drive recovery to see if it could pick anything up but it too shows the drive as having no media with 0 volumes. I have tried disabling it in device manager as well. Also tried to update the drivers.
The IDE drive itself is perfectly fine. When I put it back in my old IDE computer that it came from it boots up Windows XP and everything just fine an all of my data is on there just as it was 10 years ago.
Problem is that I have a nasty virus/corrupted system files on that drive that prevents me from installing anything on it and the copy and paste function doesn't work and neither does drag and drop. So basically I have my external HD plugged into my old computer, I have all of my files on my old computer, but I have no way to transfer them off of it. I tried to install WD utilities on my old computer to let my external HD just back the whole thing up but even that won't work. Windows installer is corrupted. I can't enable clipbook to make copy and paste work, no matter what I do in system or regedit it still doesn't work.
So I can see all of my old files, I can access them on that old computer, but I want to get them off of that ASAP and on to an external drive because I feel like that old WD IDE drive is on its last legs.
I simply want to plug it into my new computer via the IDE/USB adapter and copy the stuff off of it like I do with every single other drive I have laying around here. But only this drive refuses to show up as anything but "No media".
I don't have another old computer to hook it up to as a slave drive with an IDE port so I'm stuck using the adapter.
I have tried using the adapter to hook it up to my laptop as well at the same problem remains.
Would whatever is wrong with that old drive (virus of corrupt system files) prevent it from showing up via the USB adapter in my other computers? A corrupted partition perhaps? It boots up fine in the original old computer though so I would think it would show up in the new ones?
Any help would be greatly appreciated.
One thing that comes to mind is, "How old"? We are all accustomed to older HDD's, including IDE units, from the late 1990's etc. that use what is knows as LBA support (Logical Block Addressing) and included features to report many of their characteristics to a HDD controller system for self-configuration. But before those became dominant, the older IDE drives were accessed using a system often called "CHS" for "Cylinder / Head / Sector". Access to the HDD required that the system provide to the HDD unit a set of three parameters to specify the exact Sector to be accessed. As part of this, the HDD configuration in BIOS Setup had to be given the maximum values for each of these. Such old HDD's had on their labels the max values for...
Tried that as well. I moving the jumper to all slots, master, slave, cable, and removing it altogether. The problem still remains.
Very strange. I used to use one of those for lots of recovery and as long as I managed to get the jumper right(master or single for WDC) it always worked.
You may get stuck using an older IDE enabled system to get your files(since you have confirmed the drive is functional).
if your old pc network still works turn on file sharing and network sharing. make a new home network nasme in xp and on your other pc. make a shared folder on both pc and drag and drop the files you need. another trick is go to main anti virus sellers web page and make a virus rescue cd or usb stick and try cleaning the virus from your older pc.
Well to update I was able to successfully get the data off of the old computer. I finally found a backup program that would actually install on that old hard drive and I simply connected my external drive to it and let the program transfer the files.
Still not sure why that drive refuses to connect to my new PC but at least I got what I needed off of this old drive.
I'll still try to figure out a solution to getting this drive to connect to my PC using some of the tips I've seen here.
Thanks everyone
One thing that comes to mind is, "How old"? We are all accustomed to older HDD's, including IDE units, from the late 1990's etc. that use what is knows as LBA support (Logical Block Addressing) and included features to report many of their characteristics to a HDD controller system for self-configuration. But before those became dominant, the older IDE drives were accessed using a system often called "CHS" for "Cylinder / Head / Sector". Access to the HDD required that the system provide to the HDD unit a set of three parameters to specify the exact Sector to be accessed. As part of this, the HDD configuration in BIOS Setup had to be given the maximum values for each of these. Such old HDD's had on their labels the max values for Cylinder, Head and Sector, to be entered into BIOS Setup. Then the BIOS option needed to be set to use that addressing system, rather than using LBA Support. IF your older computer was set up this way already, that would explain why it can use that drive, but a different computer (configured differently) cannot.
