Hi guys,
so basically I have the dilemma of picking the colour of my coolant for my very first custom water cooling loop, I have included a picture of my case:
http://i296.photobucket.com/albums/mm195/alichowry1998/635685504532651822_zpssthc4zeh.jpg
it is a fractal design core 1000 (I'm on a budget here!) and so basically I painted the inside of the case a bright white to give it a bit of colour and originally I was going to use Mayhems Pastel White coolant to match the paint I did inside the case, but once I painted it and put all my components back into it I feel as though if I go for a white coolant it might be just a bit too much, so I have four choices that I am struggling to choose from, the first is white, the second is black but obviously you might argue black will also look overused since I braided all my cables black, a light baby blue solid coolant also by mayhems pastel and last a darker blue UV coolant
I have included links to other peoples builds with all these colours:
the white one
http://cdn.overclock.net/1/13/350x700px-LL-1328568d_DSC_8160.jpeg
the black one
http://cdn.overclock.net/a/ad/500x1000px-LL-ad90cefe_IMG_1976.jpeg
the light blue one
http://www.google.co.uk/imgres?imgurl=http://img.tapatalk.com/31b023e6-9db5-55f1.jpg&imgrefurl=http://www.overclock.net/t/1286896/mayhems-users-club&h=612&w=816&tbnid=EnL5ma67slr2CM:&zoom=1&docid=EFn8UBSrmHdh1M&ei=eYlpVcziJcyV7Abj7oKoBg&tbm=isch&ved=0CB8QMygAMAA
the darker blue one
http://i.kinja-img.com/gawker-media/image/upload/s--OoJYmD3G--/18mq8l27f1hspjpg.jpg
Hope you can help! Thanks!
the white one
the black one
the light blue one
the darker blue one
