Hi
i am not sure if this is in the right section.
i have speedfan installed to look at temp but i am unsure what one the CPU one is.
there are two which i think could be the CPU but am not sure. the first one is on the IT8721F chip and the snsor is Temp1. However, another temp is on the AMD K10 chip and the sensor is Core.
The IT8721F temp is always higher that the AMD K10. the IT8721F temp goes above 62 degrees which is the max operating temp said by CPU world (link below).
I have the asus m5a97 pro motherboard and the AMD Phenom II 1090T processor
thanks in advance
http://www.cpu-world.com/CPUs/K10/AMD-Phenom%20II%20X6%201090T%20Black%20Edition%20-%20HDT90ZFBK6DGR%20%28HDT90ZFBGRBOX%29.html
EDIT:
I have installed hardware monitor and i think that the lower temp is a single core of the processor. is the max operating temp for cores? and what would the other temp be, the CPU socket?
thanks in advance
EDIT:
