Identifying which system backups are of my current build.
The problem with having a dozen (more, actually) backup drives around is that I eventually lost track of what was on each. How can I identify which backups are on the path to my current system state?
I have only the OS on my system drive and do complete backups. It was my practice to restore the last backup before making changes and then do a new backup. It kept the system young.
Enter a two-year hiatus as other things happened in my life. Now I'm trying to find the most recent backup before my current build; there are backups for at least four other builds out there and they may overlap in time.
My best guess here is a simple most recent date. What I intend to do is restore one at a time to a separate SSD and boot them. When I find one that is a predecessor to my current state I'm done. But how do I tell if I've got a restore from the correct system build? My current guess is that user IDs in file ownership will map to names correctly, but any other suggestions are welcome.
See if this helps - it is included in win 10 - https://docs.microsoft.com/en-us/windows-server/administration/windows-commands/wbadmin-get-versions
https://social.technet.microsoft.com/Forums/en-US/c7665e24-cc04-41c1-95a8-20d3e32c0116/wbadmin-on-windows-10-1703?forum=windowsbackup
You need to know its version as though Build could be 1803, the version matched the patch numbers you are up to so 1803 = 17134.286. number after decimal point changes depending on patches installed.
1809 due out next few weeks so will need to figure it out before windows updates itself again.
