Idiotic problem with Dell P1130 monitor
G
Guest
Guest
Archived from groups: alt.sys.pc-clone.dell (More info?)
Hello,
I use this monitor at work, and it's very nice, but unfortunately the
front panel controls are all locked. A key symbol appears on screen
when I try to use them. I gather from the online manual that I'm meant
to be able to unlock them by pressing the menu button, but that's
locked as well. Any suggestions would be greatly appreciated.
G
Guest
Guest
If you can't access the OSD (On Screen Display) to get to the Option or
Reset menus, you are screwed. Did your IT department lock the monitors so
you couldn't mess with them? Grab your IT guy and have him unlock the
thing.
<almightygod@gmail.com> wrote in message
news:1120573787.408158.251150@z14g2000cwz.googlegroups.com...
> Hello,
G
Guest
Guest
> Hello,
Scroll about 3/4 down the page for the specific unlock instructions:
http://support.dell.com/support/edocs/monitors/p1130/english/controls.htm
hth
Stew
G
Guest
Guest
The OP is not able to access the On Screen Display (OSD) to make the
necessary changes.
"S.Lewis" <stew1960@cover.bellsouth.net> wrote in message
news:HfIye.35675$qm.7778@bignews5.bellsouth.net...
> > Hello,
> hth
> Stew
G
Guest
Guest
"Kevin" <webman6@hot4mail.com> wrote in message
news:jOidncz5E8vpb1bfRVn-3g@uci.net...
> necessary changes.
The it would appear he's farked. The manual shows a 2-key unlock
combination it appeared, rather than just pressing the menu button...
Stew
Similar threads
