Idle temps are @40C (watercooling)
stefjohn2k17
23
Hello
Two days ago I installed a custom loop on my pc and I noticed that the temps are kinda high (idle was 40c and under a stress test it goes up to 70C) I reseated the block a few times just in case it was that. I also checked for air bubbles and there are none.
What could it be?
Intel core i7 960@ 3.2ghz
ASUS Sabertooth x58
16GB Corsair Vengeance DDR3 4x4GB
GTX 1060 3GB OC
Samsung EVO 250GB SSD
Seagate 2TB HDD EVGA
Supernova 750W
I have seen way lower on OC`ed cpus (50-55C)
But what I care about is the idle temps 😀
I mean can feel the hot air from the case on me xD
Ambient temp is around 22C
At first it was running at 24-26C at idle. Thats why I think there a problem or something 😀
24-26°C idle at 22°C ambient is impossible with your cooling setup. You should only be concerned by stress test temperatures and they are excellent. If your case gets that hot with a 40°C CPU that idling in Windows, then something else in your case generates that heat (GPU, low efficiency PSU, etc.)
I didnt even mention my cooling setup xd (ek S240 kit)
It ran a whole day at 24C and 45-50C when gaming
But no... my gpu is withing normal temps and my psu is bronze 80+
Just the cpu :)
