If a just built PC goes bang on power-up...
G
Guest
Guest
Archived from groups: alt.comp.hardware.pc-homebuilt,uk.comp.homebuilt (More info?)
......what's the most likely thing I did wrong? I had a gunshot noise, a
flash, and smoke coming from (near) the PSU.
And which components are likely to be fried?
Cheers,
Fred.
"Fred Finisterre" <finisterre@gmail.com> wrote in message
news:cnts9d$4b5$1@newsg1.svr.pol.co.uk...
> Cheers,
> Fred.
i'm guessing you got a part of the mobo shorted to the chassis in which case
you'll be lucky if its only the mobo and psu gone. cpu and ram aswell if
you're unlucky
> Cheers,
> Fred.
If you're lucky it's just the voltage selector switch on the PSU set
incorrectly, in which case your PSU is fried. If it was a decent quality PSU
then all your components should be fine, if it wasn't then look on the
bright side, it's still a nice case!
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.799 / Virus Database: 543 - Release Date: 19/11/2004
> PSU then all your components should be fine, if it wasn't then look on the
It's an Antec Sonata case which comes with a 380W PSU. Where would I find
the voltage selector switch?
Cheers,
Fred.
Voltage selector switch is adjacent to power cord
connection. A red slide switch that reads either 110 or 220.
BTW, universal power supplies can be used anywhere in the
world because they electronically select this switch - don't
depend on humans. Universal supplies are standard in laptops,
camcorders, and digital cameras. Many CRT video monitors also
contain universal supplies.
Unfortunately some would respond to your question
erroneously; without first learning basic facts. Any
acceptable computer power supply can be shorted and must not
suffer damage. Every power supply output wire can be shorted
together and still damage must not result. Intel specs even
say how large this shorting wire must be.
So why would another suggest a motherboard shorted to
chassis would cause PSU failure - and RAM & CPU damage?
Things damaged because the computer assembler buys his power
supplies on hype and price rather than using good technical
numbers. Too many computer assemblers only know that if A
mates to B, then it must be so. They don't need know anything
more to be an expert. They buy power supplies missing
essential functions which is why they suffer RAM and CPU
failure. Then they blame anything but themselves - the
technically naive computer assembler - as reason for failure.
If motherboard shorted to chassis causes RAM, CPU, or power
supply failure, then reason for that failure is directly
traceable to the human who bought components. As BigH2K says:
> If it was a decent quality PSU then all your components
> should be fine, ...
Why the pop? Probably a manufacturing defect. Exactly why
a computer assembler has a 3.5 digit multimeter to verify in
but seconds where the problem is located. Procedures
demonstrated previously in "Computer doesnt start at all" in
alt.comp.hardware on 10 Jan 2004 at
http://tinyurl.com/2t69q or
"I think my power supply is dead" in alt.comp.hardware on 5
Feb 2004 at
http://tinyurl.com/yvbw9 .
> I find the voltage selector switch?
> quality PSU then all your components should be fine, if it wasn't
> then look on the bright side, it's still a nice case!
I think you're right. I never noticed the voltage selector switch. It was
set to 110V and I'm in the UK so should have had it set to 230V. Doh!
Bearing in mind the PSU looks like a fairly good one (True 380S), might I
have got away with just blowing the PSU?
Cheers,
Fred.
news:cntu90$j1g$1@newsg4.svr.pol.co.uk...
> Cheers,
> Fred.
Strangely, I have the same case and PSU so I can tell you that there isn't
one on this one. Good thing is if it was a faulty PSU then the rest of your
stuff is ok.
Can't really think of anything other than a PSU fault that could cause that
so you could really do with getting hold of another to test your system
with.
>noise, a flash, and smoke coming from (near) the PSU.
Hopefully you unplugged your computer immediately following that
gunshot noise.
A capacitor can make a loud bang when high voltage is applied to its
leads. I did that accidentally once.
Another possibility is mini terrorists inside of your computer
[kidding].
Usually I swap components when I want to know what is bad.
Good luck.
news:cntuqd$87i$1@newsg2.svr.pol.co.uk...
> Cheers,
> Fred.
OK, so yours DOES have a voltage selector and mine doesn't.
Probably good news I would have thought, have swapped out many PSUs where
this has happened, even when the machines were on and switched over and
never had anything other than the PSU damaged.
Sounds like you blew, at minimum, one or more of the components in the power
supply. In addition, depending on the quality of build of the power supply
unit, you may also have fried the motherboard.
DaveW
> Cheers,
> Fred.
I've never seen a computer power supply that did not include the 110/220
selector switch. What brand and model number is the one you know about that
is missing that switch?
"Fred Finisterre" <finisterre@gmail.com> wrote in message news:<cntu90$j1g$1@newsg4.svr.pol.co.uk>...
> Cheers,
> Fred.
The voltage selector, if it has one, will be at the rear of the PSU.
It's meant to switch between a 110/115V and a European 230/240-volt
line. If it's set at the lower voltage and you've connected it to your
240V line, what you heard was most probably the main filter capacitors
inside the PSU exploding - probably accompanied by a 'phffft' sound.
One poster here described it as a farting sound.
I've had a few cases like this with customers' computers and in all
cases there was no damage other than to the PSU itself.
I looked up the Antec Sonata with 380 Watt power supply. The Antec
literature shows the 110/220 selector switch.
"Papa" <bikingis@my.fun> wrote in message
news:E_wod.1583$NU3.778@newsread1.news.pas.earthlink.net...
Well mine doesn't have one so there 😛
As for you never having seen one that doesn't have a voltage selector well
you must have a very narrow field of experience in such matters. If you
really expect me to dismantle my PC so that I can provide you with a serial
number I suggest you go to bed, late night obviously make you unreasonable
Only joking with you, it's very common to have PSUs without the selector,
Antec make a UK only model of this PSU and I suppose the switch was omitted
as a cost cutting exercise. You really only need the selector if you're
using it abroad and not many people actually transport their desktop
machined around with them.
Hang on a minute, if you send me a stamped addressed Jiffy Bag I'll send
mine to you to have a look 😉
Like many Americans, I get a little provincial at times. I shouldn't assume
that the whole world uses the exact same design variations as we do.
>selector well ...
http://www.antec.com/specs/true330_spe_EU.html
>... it's very common to have PSUs without the selector,
Might be common in the United Kingdom.
Depends.
If an Intel system, probably the PSU and possibly the motherboard but
doubtful.
If an AMD system, probably the PSU and also likely that the motherboard &
CPU has gone along with it, possibly also the memory.
I.P.Freely
>Depends.
>doubtful.
Sounds like a troll (to me).
>I.P.Freely
>Path: newssvr30.news.prodigy.com!newssvr11.news.prodigy.com!newsswing.news.prodigy.com!prodigy.net!newsmst01a.news.prodigy.com!prodigy.com!news.glorb.com!newsgate.cistron.nl!transit.news.xs4all.nl!195.129.110.179.MISMATCH!bnewsoutpeer01.bru.ops.eu.uu.net!bnewsinpeer00.bru.ops.eu.uu.net!bnewspost00.bru.ops.eu.uu.net!emea.uu.net!not-for-mail
>From: "I.P.Freely" <i.p.freely@spamblockdsl.pipex.com>
>Newsgroups: alt.comp.hardware.pc-homebuilt,uk.comp.homebuilt
>References: <cnts9d$4b5$1@newsg1.svr.pol.co.uk>
>Subject: Re: If a just built PC goes bang on power-up...
>Date: Tue, 23 Nov 2004 08:03:39 -0000
>X-Priority: 3
>X-MSMail-Priority: Normal
>X-Newsreader: Microsoft Outlook Express 6.00.2800.1437
>X-MimeOLE: Produced By Microsoft MimeOLE V6.00.2800.1441
>Lines: 20
>Message-ID: <41a2ef0e$0$15428$cc9e4d1f@news-text.dial.pipex.com>
>NNTP-Posting-Host: 81-178-70-239.dsl.pipex.com
>X-Trace: 1101197070 news-text.dial.pipex.com 15428 81.178.70.239:1722
>X-Complaints-To: abuse@uk.uu.net
>Xref: newsmst01a.news.prodigy.com alt.comp.hardware.pc-homebuilt:422710
serial
omitted
I've also seen PSUs with the selector switch, but upon inspection it is
determined that the selector switch isn't wired up to anything inside of the
unit. Probably cheaper to throw them in all units but only wire up the ones
heading to non-US areas.
Jon
is
inside of the
the ones
> Jon
That's one of the craziest things I've heard in awhile. Imagine the
frustration and danger if those PSUs would ever to venture out of the
local.
In article <cntuqd$87i$1@newsg2.svr.pol.co.uk>, Fred Finisterre
<finisterre@gmail.com> writes
If you're very lucky, you might even have got away with just blowing the
fuse inside the PSU.
Thoss
"John Doe" <jdoe@usenet.is.the.real.thing> wrote in message
news:Xns95A9DFB24B06wisdomfolly@151.164.30.42...
>>selector well ...
I have two Antec Sonata's bought 12 months apart, neither have power supply
selectors ;o)
Steve
news:Xns95AA178424622wisdomfolly@151.164.30.42...
> >Depends.
> >doubtful.
Nope, I was being serious.
I.P.Freely
"Fred Finisterre" <finisterre@gmail.com> wrote in news:cntuqd$87i$1
@newsg2.svr.pol.co.uk:
Are there any regulations regardin selling stuff with the switch set
appropiately for the relevant country? I suspect (just a hunch) legally the
buyer is not completely at fault in this case. Anyone?
Lordy
>> >Depends.
>> >doubtful.
Seriously trolling?
What is your opinion based on?
>I.P.Freely
>Path: newssvr30.news.prodigy.com!newsdbm03.news.prodigy.com!newsdst01.news.prodigy.com!newsmst01a.news.prodigy.com!prodigy.com!news-FFM2.ecrc.net!uio.no!news.tele.dk!news.tele.dk!small.news.tele.dk!lnewsoutpeer00.lnd.ops.eu.uu.net!lnewsinpeer00.lnd.ops.eu.uu.net!bnewsoutpeer00.bru.ops.eu.uu.net!bnewsinpeer01.bru.ops.eu.uu.net!bnewspost00.bru.ops.eu.uu.net!emea.uu.net!not-for-mail
>References: <cnts9d$4b5$1@newsg1.svr.pol.co.uk> <41a2ef0e$0$15428$cc9e4d1f@news-text.dial.pipex.com> <Xns95AA178424622wisdomfolly@151.164.30.42>
>Date: Tue, 23 Nov 2004 10:07:35 -0000
>X-Priority: 3
>Lines: 27
>Message-ID: <41a30c1a$0$29084$cc9e4d1f@news-text.dial.pipex.com>
>X-Trace: 1101204506 news-text.dial.pipex.com 29084 81.178.70.239:2266
>Xref: newsmst01a.news.prodigy.com alt.comp.hardware.pc-homebuilt:422719
