If I will connect blight/repeater router to other router, wireless internet will be faster
AndrePC101
14
Hi everyone
I have 2 router. 1 is a normal router connected to ethernet and the second 1 is bright the first one. The bright router seems slow, it has 1Mbt than 2Mbts wireless internet speed. So I thought if I connect other router to brighted router with lan it will be better wireless connection or not.
Pls tell yes or not.
If you connect your repeater/access point via ethernet instead of wireless it should be faster yes.
As a wireless repeater it has to use half of its bandwidth of the radio to communicate with the primary router.
You are saying I should buy 50m ethernet wire to connect the repeating router.
I can't do it.
I don't even know if it is repeating. My router call it wan medium type.
Anyway, I want to tell you if I connect other router which Ap routher and the other one is giving wireless internet it will be better.
HOME-ROUTER---wireless--->AP-ROUTER---lan--->ROUTER WITH WIFI
You said "So I thought if I connect other router to brighted router with lan it will be better wireless connection or not."
Which means running an ethernet cable from router to router, thats why i said yes that is better.
Lets just start over, what are you wanting to do, dont try to use networking terms because misusing them is just more confusing.
