If u OC a FX 8300,will it be on par with the 8320??
aikor
305
As the title says wil it be??
Also 2nd question..
Is it better than the FX 6300(3.6ghz)while FX 8300 is 3.3 ghz at stock in game performance?
That's because you bought an OEM tray processor without fan instead of a boxed one which comes with a stock fan but there's nothing wrong with that though.
Hey u sure..iv seen that its 95W and is it good for gaming than the FX 6300??
Oh im planning to OC it upto 4GHZ...so i ordered it online
ITs weird tht it comes from a "plastic casing " in every list instead of a "box package" i wonder why is tht
Oh so the FX 8300 is basically the same as the FX 8320 right with just a low power consumpiton..i hope there wont be a big performance difference between the FX 8320
To my knowledge the 8300 was sold to OEM PC makers. It's a lower wattage part to keep heat down since this would be sold in a prebuilt PC to the average consumer who most likely won't clean their PC it won't generate a crazy amount of heat when it gets dusty causing the owner to call for service is my take on it. Take a look at CPU world for more information.
http://www.cpu-world.com/CPUs/Bulldozer/AMD-FX-Series%20FX-8300.html
Oh nice..now i just have to hope its performance is not worse than the FX 6300..this processor is barely mentioned on the internet
