Im building my first pc
Maximiliano_2
Commendable
Dec 13, 2016
5
This is my first building a pc(gaming) and i want to know if the parts im going buy are ok for every thing and if something can be cheaper and can run at same will be very useful and if something is missing pls tell me
Parts
-DIYPC Zondda-B Black SPCC Steel ATX Mid Tower Computer Case
-WD Blue 1TB Desktop Hard Disk Drive - 7200 RPM SATA 6Gb/s 64MB Cache 3.5 Inch - WD10EZEX
-ASUS VX238H Black 23" 1ms (GTG) HDMI Widescreen LED Backlight LCD Monitor
-ASUS M5A97 LE R2.0 AM3+ AMD 970 + SB950 SATA 6Gb/s USB 3.0 ATX AMD Motherboard with UEFI BIOS
-PNY GeForce GTX 1060 DirectX 12 VCGGTX10603PB 3GB 192-Bit GDDR5 PCI Express 3.0 x16 Video Card
-Rosewill ARC-650, ARC Series 650W Power Supply, 80 PLUS Bronze Certified, Single +12V Rail, Intel 4th Gen CPU Ready, SLI ...
-Avexir Core Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 2400 (PC4 19200) Desktop Memory Model AVD4UZ124001608G-2COB
-AMD FX-8350 Black Edition Vishera 8-Core 4.0 GHz (4.2 GHz Turbo) Socket AM3+ 125W FD8350FRHKBOX Desktop Processor
-PNY CS1311 2.5" 240GB SATA III TLC Internal Solid State Drive (SSD) SSD7CS1311-240-RB
I would recommend against AMD CPU's invest $50 more and you can get an Intel i5 that's nearly twice as good.
I used that case when I was redoing my brother's build. Cheap piece of crap, wouldn't recommend.
