[SOLVED] im changing components
n0lanlzz99
56
i have dell inspiron 3650, im going to change the mobo, cpu and ram
those are the new ones
mobo : https://www.newegg.com/global/sa-en...o4 &cm_re=as_rock_pro4-_-13-157-855-_-Product
cpu : https://www.newegg.com/global/sa-en...5 9600k&cm_re=i5_9600k-_-19-117-959-_-Product
ram : https://www.newegg.com/global/sa-en...cm_re=corsair_vengance-_-20-236-419-_-Product
cpu cooler : https://www.newegg.com/global/sa-en...m_re=be_quiet_150w-_-13C-001F-00005-_-Product
and i have a powersupply and a graphics card
the only thing im going to take from the old dell pc is the hdd.
is there anything i need to know before i start building the pc?
You'll probably want check if you'll need a new case. The motherboard in the Dell PCs tend to be proprietary, and will not accept a standardized format like ATX (I'm assuming it looks like this (pages 12 and 13). The PSU should also be checked to make sure it has enough power and isn't connected to the motherboard in some proprietary way (but I think it may be alright, since companies like Dell have supposedly been getting better about standard power connectors (I think)).
yeah that's right i forgot to mention that i already have a case, thank you though!
