[SOLVED] I'm confused with front panel connections on Lian Li O11D Mini PC case ?
Sep 29, 2021
Hello! I'm a noob builder.
I want to buy Lian Li 011D Mini and a B550 Aorus Elite AX V2 mobo.
My question is that the case has 2 USB 3.0 ports and the mobo has an "1 x USB 3.2 Gen 1 header", can i connect those 2 ports in that header?
Lastly, the case has a USB 3.1 type C port but mobo has an "1 x USB Type-C™ port, with USB 3.2 Gen 1 support ", will that works just fine?
Thanks!
Here is the mobo´s user manual if u want check it out!
