I'm having a problem with my GPU
cops77
12
This problem started happening after I changed my case, the screen would turn black for a second at random times (sometimes 3 times in a row), I couldn't play BF4 and Medal Of Honor because an error dialogue would appear ( http://imgur.com/yr5ee1s ), I changed the drivers a few times and still nothing changed, Now 2 games started crashing, first Saints Row 4 ( i thought it was a bug), and now AC4, I didn't try with a lot of games but i think there is something wrong with my GPU.
Specs:
CPU: Intel Core i7 2600 @ 3.40GHz
RAM: 8.00GB Dual-Channel DDR3 @ 665MHz
MOBO:H77-DS3H
GPU: 3071MB NVIDIA GeForce GTX 780 Ti (Gigabyte)
PSU: AX1200i
Understood. The reason I'm suggesting to try to move everything outside is because some cases can have grounding issues. In particular, the standoffs beneath the motherboard, sometimes even the back panel plate or front panel connectors such as USB.
cops77
12
For the CPU it would get to 45 C I think, because i have H80i for it.
As for the GPU it would get to around 65 C.
cops77
12
I didn't build the PC myself, because the building part was done by a shop, but I know how to reseat the GPU.
so I will try to do that, and to be clear I only changed the case so I can add the H80i.
cops77
12
Mine is the CM STORM Trooper.
cops77
12
Turns out this GPU is faulty, check this out
http://www.overclock.net/t/1461220/gigabyte-780-ti-ghz-edition-crashes
Those are the exact same issues am having.
