Hi,
I'm using windows vista and have recently purchased a corsair 2gb ram stick (to add to my current 2gb) bringing it up to 4gb.
However, I get different reports on the amount of RAM installed depending on what I use to check.
If I right click My Computer and choose properties, the summary shows that I have 4gb of RAM installed.
If I go to the performance tab of task manager it says I have a total of 3070mb of physical memory installed.
If I run the setup for Stalker (it shows a hardware summary before installing) it says I only have 2gb installed.
What's the deal?
Any help appreciated.
Thank you
What's the deal?
Thank you
