I'm having the same problem and when I give the command for ipconfig, the dns servers gives results as 8.8.8.8 and 202.134.160
frankmattdsouza
Commendable
Aug 9, 2016
14
I got the same problem and when I gave a command for ipconfig all, I get the following results -
Dns servers: 8.8.8.8
202.134.160.7
Did you ever change the DNS on iOS, if yes change it back to it's original (192.168.1.1) :)
You can do this on your PC too,
1.Go to the Control Panel.
2.Click Network and Internet > Network and Sharing Center > Change adapter settings.
3.Select the connection for which you want to configure Google Public DNS. ...
4.Select the Networking tab. ...
5.Click Advanced and select the DNS tab. ...
6.Click OK.
Windows 7
Hope to help! 😀
Hi
After doing the above, it auto launches windows diagnostics and says the DNS server isn't replying and brower gives an error "check proxy, firewall and Dns configuration"
having set the DNS to 8.8.8.8 is no problem at all, it's the Google DNS Servers, they're usually more stable than the probably crappy servers of your ISP
does you Firewall block port 80?
can you open the interface of your modem?
can you ping the modem`?
can you ping an IP address?
can you do a traceroute to an IP address? if it fails: where does it fail?
I can guide you through.
first right click on the start menu button and open "CMD" or "command prompt"
then enter in the newly opened window "tracert 8.8.8.8"
the first line displayed will be your modem and will look like " 1 <1ms <1ms <1ms 192.XXX.X.X"
the IP displayed is the IP of your modem.
the traceroute will end with the words "traceroute finished". if the last line shows the IP 8.8.8.8, then your connection is generally fine. if it doesn't or there's an error on the way, copy+paste it here.
either way inform us about the results pls.
Windows 10
1.Open Control Panel
2.Click on Network and Sharing Center
3.Click on Change adapter settings
4.Right click on your network and click properties
5.Scroll down and double click Internet Protocol Version 4
6.Press use the following DNS server adresses
7.Set Preferred DNS server as: 192.168.1.1
8.Set Alternate DNS server for an alternate one ex. 8.8.8.8
9.Click OK.
Hope this helped! :)
Hello,
I executed the command tracert 8.8.8.8 and it returned this:
1 3ms 2ms 2ms 192.168.2.1
2 5Ms 4Ms 3Ms 202.134.182.46
3 17ms 18ms 9ms 202.134.182.37
4 4ms * * 10.31.31.2
5 6ms 4Ms 4Ms 202.134.152.25
6 4ms 4 Ms 4ms 209.85.142.171
7 5ms 4ms 4ms 8.8.8.8
Trace complete
Try setting both to 192.168.1.1, and inform us what happened :)
Hi Isokolon,
Changed the DNS to the ones you asked.
No change. The error message on the browser window says "twitter.com unexpectedly closed the conn. Try: checking the connection, checking the proxy and firewall"
are you sure FB works and you're not shown just a chached version of the site?
because it very much looks like the dns decyprtion doesn't work
normally, setting your dns servers manually it should work just fine unless your ISP has some twisted settings on their end
