Question I'm in desperate need of help with Kernel Error: 41 ?
Jan 2, 2025
my pc keeps getting bsod, even after geek squad looked at it but i finally have the minidump.....
************* Preparing the environment for Debugger Extensions Gallery repositories **************
ExtensionRepository : Implicit
UseExperimentalFeatureForNugetShare : true
AllowNugetExeUpdate : true
NonInteractiveNuget : true
AllowNugetMSCredentialProviderInstall : true
AllowParallelInitializationOfLocalRepositories : true
EnableRedirectToChakraJsProvider : false
-- Configuring repositories
----> Repository : LocalInstalled, Enabled: true
----> Repository : UserExtensions, Enabled: true
>>>>>>>>>>>>> Preparing the environment for Debugger Extensions Gallery repositories completed, duration 0.000 seconds
************* Waiting for Debugger Extensions Gallery to Initialize **************
>>>>>>>>>>>>> Waiting for Debugger Extensions Gallery to Initialize completed, duration 0.032 seconds
----> Repository : UserExtensions, Enabled: true, Packages count: 0
----> Repository : LocalInstalled, Enabled: true, Packages count: 42
Microsoft (R) Windows Debugger Version 10.0.27725.1000 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\Minidump\010225-12156-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: srv*
Executable search path is:
Windows 10 Kernel Version 26100 MP (32 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS Personal
Kernel base = 0xfffff800`9bc00000 PsLoadedModuleList = 0xfffff800`9caf4850
Debug session time: Thu Jan 2 19:41:52.064 2025 (UTC - 6:00)
System Uptime: 0 days 0:04:21.756
Loading Kernel Symbols
Loading User Symbols
PEB is paged out (Peb.Ldr = 000000d2`d56d8018). Type ".hh dbgerr001" for details
Loading unloaded module list
************* Symbol Loading Error Summary **************
Module name Error
ntkrnlmp 0xc00 - The caller specified wait timed out before the operation completed because resources are being acquired.
You can troubleshoot most symbol related issues by turning on symbol loading diagnostics (!sym noisy) and repeating the command that caused symbols to be loaded.
You should also verify that your symbol search path (.sympath) is correct.
For analysis of this file, run !analyze -v
nt!KeBugCheckEx:
fffff800`9c0b85d0 48894c2408 mov qword ptr [rsp+8],rcx ss:0018:ffffc487`2924e330=0000000000000050
8: kd> !analyze -v
* Bugcheck Analysis *
PAGE_FAULT_IN_NONPAGED_AREA (50)
Invalid system memory was referenced. This cannot be protected by try-except.
Typically the address is just plain bad or it is pointing at freed memory.
Arguments:
Arg1: ffffffffffffffff, memory referenced.
Arg2: 0000000000000000, X64: bit 0 set if the fault was due to a not-present PTE.
bit 1 is set if the fault was due to a write, clear if a read.
bit 3 is set if the processor decided the fault was due to a corrupted PTE.
bit 4 is set if the fault was due to attempted execute of a no-execute PTE.
- ARM64: bit 1 is set if the fault was due to a write, clear if a read.
bit 3 is set if the fault was due to attempted execute of a no-execute PTE.
Arg3: fffff8009be3065f, If non-zero, the instruction address which referenced the bad memory
address.
Arg4: 0000000000000002, (reserved)
Debugging Details:
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
*** Either you specified an unqualified symbol, or your debugger ***
*** doesn't have full symbol information. Unqualified symbol ***
*** resolution is turned off by default. Please either specify a ***
*** fully qualified symbol module!symbolname, or enable resolution ***
*** of unqualified symbols by typing ".symopt- 100". Note that ***
*** enabling unqualified symbol resolution with network symbol ***
*** server shares in the symbol path may cause the debugger to ***
*** appear to hang for long periods of time when an incorrect ***
*** symbol name is typed or the network symbol server is down. ***
*** For some commands to work properly, your symbol path ***
*** must point to .pdb files that have full type information. ***
*** Certain .pdb files (such as the public OS symbols) do not ***
*** contain the required information. Contact the group that ***
*** provided you with these symbols if you need this command to ***
*** work. ***
*** Type referenced: nt!_KTHREAD ***
*** work. ***
*** Type referenced: nt!_IMAGE_DOS_HEADER ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** Type referenced: nt!_KPRCB ***
*** work. ***
*** Type referenced: nt!KPRCB ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** Type referenced: nt!_EPROCESS ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
KEY_VALUES_STRING: 1
Key : AV.Type
Value: Read
Key : Analysis.CPU.mSec
Value: 46
Key : Analysis.Elapsed.mSec
Value: 47
Key : Analysis.IO.Other.Mb
Value: 0
Key : Analysis.IO.Read.Mb
Value: 1
Key : Analysis.IO.Write.Mb
Value: 0
Key : Analysis.Init.CPU.mSec
Value: 125
Key : Analysis.Init.Elapsed.mSec
Value: 35678
Key : Analysis.Memory.CommitPeak.Mb
Value: 65
Key : Analysis.Version.DbgEng
Value: 10.0.27725.1000
Key : Analysis.Version.Description
Value: 10.2408.27.01 amd64fre
Key : Analysis.Version.Ext
Value: 1.2408.27.1
Key : Bugcheck.Code.LegacyAPI
Value: 0x50
Key : Bugcheck.Code.TargetModel
Value: 0x50
Key : Dump.Attributes.AsUlong
Value: 21808
Key : Dump.Attributes.DiagDataWrittenToHeader
Value: 1
Key : Dump.Attributes.ErrorCode
Value: 0
Key : Dump.Attributes.KernelGeneratedTriageDump
Value: 1
Key : Dump.Attributes.LastLine
Value: Dump completed successfully.
Key : Dump.Attributes.ProgressPercentage
Value: 0
Key : Failure.Bucket
Value: WRONG_SYMBOLS_X64_10.0.26100.2605_(WinBuild.160101.0800)_TIMESTAMP_120323-095153_4F6C47B9_nt_wrong_symbols!4F6C47B9144F000
Key : Failure.Hash
Value: {779b83ef-371e-8aff-af32-74b7e9b8bea5}
BUGCHECK_CODE: 50
BUGCHECK_P1: ffffffffffffffff
BUGCHECK_P2: 0
BUGCHECK_P3: fffff8009be3065f
BUGCHECK_P4: 2
FILE_IN_CAB: 010225-12156-01.dmp
ADDITIONAL_DEBUG_TEXT:
You can run '.symfix; .reload' to try to fix the symbol path and load symbols.
WRONG_SYMBOLS_TIMESTAMP: 4f6c47b9
WRONG_SYMBOLS_SIZE: 144f000
FAULTING_MODULE: fffff8009bc00000 nt
DUMP_FILE_ATTRIBUTES: 0x21808
Kernel Generated Triage Dump
FAULTING_THREAD: ffff920dff0dc080
READ_ADDRESS: *************************************************************************
*** work. ***
*** Type referenced: nt!_MMPFN ***
*** work. ***
*** Type referenced: nt!_MMPTE ***
Unable to get size of nt!_MMPTE - probably bad symbols
ffffffffffffffff
MM_INTERNAL_CODE: 2
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXNTFS: 1 (!blackboxntfs)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT: 1
STACK_TEXT:
ffffc487`2924e328 fffff800`9bed3c85 : 00000000`00000050 ffffffff`ffffffff 00000000`00000000 ffffc487`2924e590 : nt!KeBugCheckEx
ffffc487`2924e330 fffff800`9be7a51f : ffffffff`ffffffff 00000000`00001000 00000000`00000002 fffff800`9bc00000 : nt!MmMapLockedPagesSpecifyCache+0x15275
ffffc487`2924e420 fffff800`9c288ecb : 00000000`00000000 00000000`00000000 ffff920e`0a86c490 fffff800`9ca38680 : nt!KeReleaseInStackQueuedSpinLockFromDpcLevel+0x30ff
ffffc487`2924e590 fffff800`9be3065f : ffffffff`ffffffff ffff920e`0aacc480 002e0056`00540064 0067006f`00720050 : nt!setjmpex+0x4dab
ffffc487`2924e720 fffff800`9be2f556 : fffff800`9bc00000 fffff800`9c5b614e ffffc487`2924f9e0 fffff800`9bd2bdd4 : nt!RtlVirtualUnwind2+0x287f
ffffc487`2924e7d0 fffff800`9be2de69 : 00000000`00000001 fffff800`9bc00000 fffff800`9c5b614e fffff800`9bd2bdd4 : nt!RtlVirtualUnwind2+0x1776
ffffc487`2924e890 fffff800`9c69f830 : fffff800`9c5b614e ffffc487`2924e9d8 ffff920d`ff0dc080 ffffc487`2924f190 : nt!RtlVirtualUnwind2+0x89
ffffc487`2924e920 fffff800`9c2827d9 : ffff920d`ff0dc080 00000000`00000002 ffffdb0b`a048e950 00000000`00000000 : nt!NtCopyFileChunk+0x5000
ffffc487`2924f030 fffff800`9c4e6f53 : ffffdb0b`a048e950 00000000`00000000 ffff920d`ff0dc080 ffff920d`ff0dc080 : nt!KeSaveStateForHibernate+0x8a09
ffffc487`2924f140 fffff800`9c4e5701 : 00000000`00000000 ffffc487`2924f480 00000000`00000000 00000000`00000246 : nt!NtCompareSigningLevels+0x43f3
ffffc487`2924f380 fffff800`9c4e6165 : 00000000`00000001 ffffc487`2924faa0 ffffdb0b`a03448d0 00000000`00000001 : nt!NtCompareSigningLevels+0x2ba1
ffffc487`2924f590 fffff800`9c5b95ae : ffffdb0b`99a8a310 00000000`00000000 ffffdb0b`a03448d0 ffff920e`0a860d20 : nt!NtCompareSigningLevels+0x3605
ffffc487`2924f600 fffff800`9c5b614e : 0000029c`90955310 0000029c`90955598 0000029c`9095a0a0 00000000`00000000 : nt!NtQuerySystemInformation+0x349e
ffffc487`2924f9e0 fffff800`9c28d355 : 00000000`9c070000 ffff920d`ff0dc080 ffff920d`ff0dc080 00000000`00000036 : nt!NtQuerySystemInformation+0x3e
ffffc487`2924fa20 00007ffe`43f9fde4 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!setjmpex+0x9235
000000d2`d5dfcd28 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007ffe`43f9fde4
STACK_COMMAND: .thread /r /p 0xffff920dff0dc080 ; kb
IMAGE_VERSION: 10.0.26100.2605
EXCEPTION_CODE_STR: 4F6C47B9
EXCEPTION_STR: WRONG_SYMBOLS
PROCESS_NAME: ntoskrnl.wrong.symbols.exe
IMAGE_NAME: ntoskrnl.wrong.symbols.exe
MODULE_NAME: nt_wrong_symbols
SYMBOL_NAME: nt_wrong_symbols!4F6C47B9144F000
FAILURE_BUCKET_ID: WRONG_SYMBOLS_X64_10.0.26100.2605_(WinBuild.160101.0800)_TIMESTAMP_120323-095153_4F6C47B9_nt_wrong_symbols!4F6C47B9144F000
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
FAILURE_ID_HASH: {779b83ef-371e-8aff-af32-74b7e9b8bea5}
Followup: MachineOwner
and for the record i did click the !analyze button
Wow, hunting through that is going to be a lot of work....
Event 41 in itself isn't so much as error as a condition. People commonly like to associate it with a bad power supply, and that can be the case, but is actually just logging that the PC was not shut down properly.
For those of us that don't like hunting needles in haystacks, can you list the complete PC hardware?
Also, so you see any other errors in Event Viewer and is Reliability History showing anything useful ?
oh, also unless you have a service contract with Geek Squad and all you are doing is wasting gas and time, don't pay those idiots....
Latest posts
