I'm looking to build a computer for around 600. What would be the best parts?
Antinaxtos
127
Best value for money right here
CPU: AMD FX-8320 3.5GHz 8-Core Processor ($138.89 @ OutletPC)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($24.88 @ OutletPC)
Motherboard: Gigabyte GA-970A-DS3P ATX AM3+ Motherboard ($56.98 @ Newegg)
Memory: Crucial Ballistix Sport 4GB (2 x 2GB) DDR3-1600 Memory ($24.99 @ Amazon)
Storage: Samsung 850 EVO-Series 120GB 2.5" Solid State Drive ($67.54 @ Amazon)
Storage: Seagate 500GB 2.5" 5400RPM Hybrid Internal Hard Drive ($57.17 @ Amazon)
Video Card: MSI Radeon R9 380 4GB Video Card ($188.99 @ NCIX US)
Case: Deepcool TESSERACT BF ATX Mid Tower Case ($28.99 @ Newegg)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply ($38.98 @ Newegg)
Total: $627.41
Generated by PCPartPicker 2016-01-25 05:34 EST-0500
You make alot of bad trade offs to get that.
1. low Ram 2. low HDD space and also slow HDD space that can cause hiccups in games run off it 3. You won't ever use 8 cores for anything. 4. it runs so hot naturally you have to buy an extra expense of an aftermarket cooler.
Here's a $600 system that has the newest tech, and also an OS, unless you don't need one, which would help alot, but you probably do.
CPU: *Intel Core i3-6100 3.7GHz Dual-Core Processor ($124.89 @ OutletPC)
Motherboard: *Asus H110M-A Micro ATX LGA1151 Motherboard ($49.99 @ Amazon)
Memory: *Kingston HyperX Fury Black 8GB (1 x 8GB) DDR4-2133 Memory ($40.99 @ Amazon)
Storage: *Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($48.88 @ OutletPC)
Video Card: EVGA GeForce GTX 950 2GB Superclocked+ ACX 2.0 Video Card ($144.99 @ Amazon)
Case: *Deepcool TESSERACT BF ATX Mid Tower Case ($28.99 @ Newegg)
Power Supply: *EVGA 430W 80+ Certified ATX Power Supply ($33.99 @ SuperBiiz)
Optical Drive: *Lite-On iHDS118-04 DVD/CD Drive ($12.89 @ OutletPC)
Operating System: *Microsoft Windows 8.1 OEM (64-bit) ($89.99 @ NCIX US)
Total: $575.60
*Lowest price parts chosen from parametric criteria
Generated by PCPartPicker 2016-01-25 12:03 EST-0500
Kreignitz
17
Just saying, you could get a 2x4 GB RAM kit a little bit cheaper and it should up the minimum FPS by a miniature amount compared to 1x8. Not a big difference, but it's normally cheaper, so why not? Also you should really get an ASRock motherboard because they have unlocked base clock on Skylake processors (like the i3 6100 James suggested). This means it's basically overclockable. Other MOBO manufacturers will probably also include this sooner or later, but buying an ASRock now would be a safe bet now.
Not true. Dual channel vs single channel ram won't make a difference for 99.9% of games/applications. A single channel 1066 speed ram would be slower than a dual-channel 1600 speed ram, and that's likely what most people who make that claim are doing.
Kreignitz
17
Well, that's basically what I meant. An incremental increase in performance for a few bucks less. In local stores near me the difference is up to 15$ so it's worth considering if no online retailer is handy for him as is the case with me.
