Yes, so you have to buy a NEW power supply that has the correct power connections. Your current power supply is insufficient for your proposed graphics card.I already have a power supply but there is only a 6pin connection coming out of it and i need a 6pin + 8pin![]()
You have to buy a power supply also.Can i buy a cable so that i can use the psu on the gfx card or do i need a new psu because it doesnt have enough cables coming out of it? Thanks in advance![]()
I already have a power supply but there is only a 6pin connection coming out of it and i need a 6pin + 8pinYou have to buy a power supply also.
So i need to look for a power supply that says it has both?Yes, you need a new PSU.
Okay thanksYes, so you have to buy a NEW power supply that has the correct power connections. Your current power supply is insufficient for your proposed graphics card.
Any good quality power supply of sufficient wattage will have the needed outputs.So i need to look for a power supply that says it has both?
