Immediate Help! Cpu about to die?
VyborBandit
30
So I Currently Have a Thread Open About My Cpu, Its Temperatures Were Getting Beyond a Joke, and Was Down Clocking Alot, Time Has Gone on and I Have Redone My Pc, Fans,paste, Everything.. Earlier I Turn on My Pc After Giving It a Stress Test and All Was Fine... Now I Went to Open Up Core Temp and as I Did This I Had a Bsod... I Have Never Since the Day I Bought This Pc When It Was a Piece of Junk Had a Bsod. (I Bought It as a Custom Build That Basically Only Came I with a Good Cpu. the Rest Was Cheap Junk and Ive Upgraded Every Part) the Error Was "Memory_management" I Have Tried to Diagnose My Ram Etc and It Didn't Find Anything.. I Noticed My Pc Was Kinda Slow and Now My Clock Speeds Are Completely Unstable. https://gyazo.com/b00f894e10a83d86f88c023985c4f818 This Gyazo Is Not a Very Good Representation but Its Going from 3.9 to 2.9 to 1.3 and Then Up and Down Up and Down... I Have Put Al Ot of Time and Money in to This Pc and I Kinda Dont Want to Have to Buy Alot of New Components, If I Need to Get a New Cpu I May as Well Buy an Intel but the Downside Is That I Have a Mobo Thats a Month Old and I Wont Fit...
Thanks, I Have Had a Lot of Help from You Guys on the Forum in recent times and Its Greatly Appreciated
Edit:: One thing to note, this Cpu has never been Over clocked.. always been at stock speeds.
Not necceasriy. I've had a BSOD with something similar. Sometimes the software (such as coretemp) has trouble reading the temperature sensors and it causes a BSOD.
Don't be too upset. The unstable clock speed is also a "feature" to make the cpu more efficient. All systems have this enabled by default. you can disable it in the BIOS if it bothers you.
Okay i hope thats right, the unstable clocks has never happened before, which is why it caught me off guard, also because of the other problems im having with it i just didnt want to blow like £200 on a new cpu.. Thanks <3
