I'm a budget gamer
I know it's a very old topic. But I'm about to upgrade from my ancient gtx 560 ti and I'm planning to do so tomorrow on a 970 because my pc is getting hiccups with all the "next gen" games (watch dogs, ryse, shadow of mordor). I can't stand looking at the all blurred images, especially with all the new games coming this November, I need an upgrade fast.
Browsing through the web the final time before buying though I found a very hot debate between the upcoming 8GB version vs the current 4 GB.
There seems to be 2 sides, and I'm extremely confused because I'm upgrading soon and now I'm facing this debate which is causing me a headache (a lot).
One side claims that vram occupation doesn't impact fps (like at all), but it helps reducing stuttering.
Another claims that 970 chip with 256 bit bus cannot utilize 8gb and when games need 8gb, the 970 will be as my 560 ti right now.
So my question is, should I wait? More information about my spec: I'm playing at 1600x900 and I'm very happy with it and not planning to upgrade it anytime soon. My budget is also very limited (as you can see, 560 ti to 970), so I won't be able to have an SLI build and I'm planning to have a long-term upgrade (hopefully as long as my 560ti has served me)
I know the gpu can use system RAM when its VRAM is full (as I'm forcing high texture with shadow of mordor AND Ryse with playable fps from 25-40 with a bit of tweak here and there), so can I use this method as a shot in the dark for the 970 4GB and see how it turns out?
