Question In help of chosing router for low gaming
Klaus235
Commendable
Mar 1, 2022
76
First of all sorry for my english if you can't understand write it
here is my routers and i will add some few more in next week that will come
i want my routers to have two ports copper and optic
tp link WR844n
ac1200 smart dual band
r4cm xiaomi Router 4c
Huawei echolife hg8012h
If the router has a optical interface your options are going to be limited.
"optical port" really means nothing since different ISP use different settings.
Your best option is to check the ISP site for a recommended device.
If you are doing gaming you want to use ethernet cables. Almost all routers are the same when you use ethernet and you should never play games on wifi anyway. Pretty much any device that has a optical port that will connect to your ISP will work fine.
Maybe start out with a router you rent/lease from the ISP so you know it will work. Then when you know the model that works you can look for a similar one to buy.
