[SOLVED] In Need of New Computer Parts.
LDavis213
41
Hi there.
My computer is on it's last legs, sort of.
I'm hoping to upgrade my motherboard, Ram and CPU.
Here are my current specs:
AMD FX 8350 Eight Core Processor
16GB RAM
GeForce GTX 1080 Aero OC 8GB
Asus M5A97R2.0
Thermaltake 650W PSU
Windows 7 x64
And a neat Asus Xonar DG sound card. Which I believe causes many problems.
I am looking for a motherboard with many SATA slots. My MB has six and are all in use.
I suppose up to 8 RAM slots will be neat, and I heard DDR4 is quite fancy.
I have no clue what CPU is required, but I hear AMD isn't so great and that the one I have isn't so good.
Thank you very much for reading!
If you can swing it, you might start here with an Intel build:
PCPartPicker Part List
CPU: Intel Core i5-9600K 3.7 GHz 6-Core Processor ($199.99 @ Best Buy)
CPU Cooler: CRYORIG H7 49 CFM CPU Cooler ($55.74 @ Amazon)
Motherboard: MSI Z390-A PRO ATX LGA1151 Motherboard ($129.99 @ Amazon)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-2400 Memory ($49.99 @ Newegg)
Total: $435.71
Generated by PCPartPicker 2019-12-14 06:27 EST-0500
or here for an AMD build
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor ($189.99 @ Best Buy)...
Stick with either of the two builds I recommended at first. The RAM I linked later on was JUST AN EXAMPLE of not mixing RAM kits. With an Intel build, I'd recommend DDR4-2400 RAM. With the AMD build, go with DDR4-3200 RAM as the AMD CPU can take advantage of the faster RAM.
-Wolf sends
Oops, apologies.
I thought you were giving me an example of kits as you said, if I want 32GB, purchase a kit. And you given me two examples and told me not to get the third kit.
I understand not to mix kits now.
I was set on the Intel build you offered. But I may steer towards the build Hellfire has offered as you and they say the AMD CPU is better RAM wise.
