So, I'll go through this briefly:
One day, I had to move my computer from one place to another, ( this included a car drive ).
When I had installed the computer on the second place and booted it up, everyone went fine until these CPU Temperature errors started popping up, saying that my CPU was at like 65 - 75 degrees in idle, I ignored it and hopped into a game with my friends and after 10 - 15 minutes my computer shutdown, the cause of the shutdown was the CPU Temperature readings.
So, I've done alot of testing and have come to the conclusion that my CPU Sensors are invalid, both the temperature ones, and the CPU Fan Speed ones.
This is troublesome since my BIOS, sometimes doesnt let my computer to boot up since it doesnt think my CPU Fan is spinning ( when it actually is ), although, this is random, and sometimes it works. The same thing goes for the temperature, my idle temperature is everything from 30 degrees up to 60, and it's all random. Sometimes, It jumps from 30 degrees to 60, in an instance, and then back to something like 40.
My CPU is the AMD FX 8370 and the fan is the one that comes with it, I dont know the exact model.
Would getting a new CPU work, as I already have plans on doing that?
Or is there some other possible fix for this, help will be greatly appreciated.
Here's a picture of the graphs, showing the spiky temperatures:
And although I can't show any graphs for the fan speed, you'll have to take my word for that it constantly jumps from 1200 RPM to 0 RPM, within seconds, also seeming to be random.
