G
Guest
Guest
I came accross a Compaq presario 7000US 1.2GHz Athlon, 200MHz fsb, kt133 chipset equipped from factory with 128MB pc100. Since the closely related 7000Z model is equipped with pc133 SDRAM from factory, it seemed to be a waste to have the memory bus work at only 100MHz. The motherboard has a jumper labeled [1 2]100MHz/[2 3]133MHz so I replaced the pc100 memory with Crucial pc133 and set the jumper to 133MHz. The PC does not boot (graphic card is not even initialised). Not surprising since I am not sure what the jumper is supposed to do. Any thoughts on the next step.
